3.6 vram install & 915 rebuild progress report
It looks like I'm one of many in the crowd performing a 3.6 conversion right now, but I thought I'd share my project with the group. I'm replacing the stock 2.7 in my 1977 911S with a 1997 3.6 Vram. I went with a US OBDII engine with the drive block disabled and mapping updated by Steve Weiner at Rennsport Systems. During the conversion, I'm also replacing both rear wheel bearings, the CV joints & half shafts, a million other little things, rebuilding the 915, and adding a GT LSD. If you have any questions, I'd be happy to enlighten you on the decisions I made, and why I made them. Here we go:
http://mywebpages.comcast.net/rfusi/27_2.jpg Original 2.7 in the car http://mywebpages.comcast.net/rfusi/enginesoundpad.jpg This is the engine bay with the 2.7 removed. The sound pad was disintegrating, so I either had to sand & repaint or replace the pad http://mywebpages.comcast.net/rfusi/...ay_painted.jpg I decided to sand & paint http://mywebpages.comcast.net/rfusi/big_reds/br8.jpg I'm also having the transmission completely rebuilt, and a GT LSD added. This is a picture of the transmission installed in the car before the project http://mywebpages.comcast.net/rfusi/...se_cleaned.JPG This is the case completely cleaned and painted. I think I lost 10lbs just by removing the sludge ;) http://mywebpages.comcast.net/rfusi/conversion8.jpg Here's the old 2.7 out of the car. It dyno'd at 115 rwhp on a Dynapack dyno last week. http://mywebpages.comcast.net/rfusi/conversion9.jpg Another view of the 2.7 http://mywebpages.comcast.net/rfusi/conversion9a.jpg A final view of the 2.7 more to follow in an additional post |
I purchased my engine from LA Porsche. They gave me a 6 month warranty, and have been excellent at sending out the few pieces that were either missing or broken when the engine arrived. Here are more pics of the project:
http://mywebpages.comcast.net/rfusi/36_1.jpg 1997 3.6 Varioram upon arrival http://mywebpages.comcast.net/rfusi/36_3.jpg http://mywebpages.comcast.net/rfusi/36_4.jpg I did quite a bit of research and archive searches on exhaust solutions for the 3.6 conversions. It seems as though most have gone with B&B headers and the Fabspeed/Flowmaster muffler. Others have used the excellently flowing factory 993 heat exchangers and adapted some type of custom muffler, or have used the factory catalytic converters with tips welded to the ends. My shop has been fabbing a nice system with mandrel bent pipes and Spintech mufflers, but I chose to go the same route as EMBS with the Triad muffler. I spoke to Dave at Triad, and I essentially have the second muffler he's made for this application. It bolts to the factory heat exchangers, and has provisions for the O2 sensors. I will have 2 O2 sensors, so I asked him to leave the bungs off so my shop can place them appropriately without interference. I will have my car dyno'd again on the Dynapack dynamometer once everything is installed. Unfortunately, this won't be a very good a/b comparison for exhausts since my car will have computer mapping by Steve Weiner instead of the Steve Timmins'-popularized euro OBDI setup with Cyntex chips. Nevertheless, we should be able to tell if the Triad muffler greatly hinders power. Below is a picture of my Triad muffler, just before shipment. http://mywebpages.comcast.net/rfusi/my_triad.JPG The white X's are where he wanted to put the O2 sensors (I need 2 since I'm running US OBDII), and the white boxes are close to the factory locations. |
I visited my shop this weekend, and took some pictures of the work in progress. They are as follows:
http://mywebpages.comcast.net/rfusi/conversion1.jpg http://mywebpages.comcast.net/rfusi/conversion2.jpg http://mywebpages.comcast.net/rfusi/conversion3.jpg http://mywebpages.comcast.net/rfusi/conversion3a.jpg http://mywebpages.comcast.net/rfusi/conversion4.jpg http://mywebpages.comcast.net/rfusi/conversion4a.jpg http://mywebpages.comcast.net/rfusi/conversion5.jpg 3.6 Vram engine being prepared for installation http://mywebpages.comcast.net/rfusi/conversion6.jpg http://mywebpages.comcast.net/rfusi/conversion7.jpg That is the current state of affairs. It will probably be done in another couple of weeks, as the tranny needs to be re-assembled and the rest of the project sorted. My shop has never installed the 964-based RS heat tube being reproduced by Thom Fitzpatrick, but I'll post pics with their modifications. If anyone has pics of the area where the bottom of the tube meets up with the factory "heat pipe" (sorry, I can't remember the actual name right now), I'd appreciate seeing how you overcame this issue. I'll keep you posted! |
Looking great! You are having a lot of the same “while your in there’s” done as I did; tranny, bearings, CVs, etc. Clean exhaust setup, I think that’s the way I would go if I had a 993 engine. Good Luck!
Great job!!
Show them some better pictures of your brakes;) |
Invisible rotors? Or did you go a little crazy drilling holes? I bet those stay cool!
http://mywebpages.comcast.net/rfusi/at-park.jpg |
How could anyone even think about a 964 or 993 when they could have something like that.
:) Did you manage to ditch the SAI? |
This is part of a thread from my 993TT brake upgrade over the summer:
I spent about 3 hours in the garage installing the right rear brake. The first thing I did was weigh the new brakes. I weighed the caliper, the caliper and pads, and the caliper, pads & rotor together. I used a digital scale that rounds to the nearest .5lb. My results for the 993TT rear brakes: Caliper: 8.0 lbs Caliper & pads: 10.5 lbs Caliper, pads, and rotor: 30.0 lbs Stock 1977 911S M caliper, pads, & rotor: 20.5 lbs (btw, the calipers were almost the same weight, the difference was almost entirely in the larger rotor/heat sink) http://mywebpages.comcast.net/rfusi/big_reds/br1.jpg Big Red on the scale http://mywebpages.comcast.net/rfusi/big_reds/br2.jpg Original brakes http://mywebpages.comcast.net/rfusi/big_reds/br3.jpg Wheel removed http://mywebpages.comcast.net/rfusi/big_reds/br4.jpg Look at that puny thing! http://mywebpages.comcast.net/rfusi/big_reds/br5.jpg Old vs. new calipers http://mywebpages.comcast.net/rfusi/big_reds/br6.jpg Old vs. new rotors http://mywebpages.comcast.net/rfusi/big_reds/br7.jpg Rotor removed (it doesn't look that rusty irl) http://mywebpages.comcast.net/rfusi/big_reds/br8.jpg New brake line installed |
More of the thread for rear brake:
http://mywebpages.comcast.net/rfusi/big_reds/br9.jpg Doh! The custom mounting tabs don't see to be fitting! I spent awhile figuring out whether the adaptor was installed correctly on the caliper, etc. http://mywebpages.comcast.net/rfusi/big_reds/br10.jpg Eventually, I figured out that I needed THIS! http://mywebpages.comcast.net/rfusi/big_reds/br11.jpg mmm...manly tools! http://mywebpages.comcast.net/rfusi/big_reds/br12.jpg I had to remove the ears that are typically used to mount the dust shields. Who needs those things, let's lighten this baby up! What else can I cut off of my car to save weight :) http://mywebpages.comcast.net/rfusi/big_reds/br13.jpg Partly cut off http://mywebpages.comcast.net/rfusi/big_reds/br14.jpg Ears = Gone http://mywebpages.comcast.net/rfusi/big_reds/br15.jpg That's better |
Last bit:
http://mywebpages.comcast.net/rfusi/big_reds/br16.jpg mmm...Big Reds http://mywebpages.comcast.net/rfusi/big_reds/br17.jpg Okay, I'll admit that I was a little nervous when I was putting the wheel on. It barely clears, but it clears! http://mywebpages.comcast.net/rfusi/big_reds/br18.jpg 3 hours later, I'm all set! Only 3 more to go! |
AWESOME Rob!
You have a very sharp car!! I think you are the only guy on the board with an OBDII 3.6 transplant. I have no idea what the Triad does from a power perspective, but I very much like how it sounds. You'll have factory motorsound lid in about three days to cover that filter. You are smart for staying away from the oiled cone filters. |
That firewall looks great with the paint, but you might want to consider putting one of the Appbiz/Pelican sound pads in there before they put the motor in. The pad is less bulky and lighter than the factory pad, and makes a noticeable difference in interior sound and heat. If it's a street-driven car, especially, it's a great way to go. (And it's also a reflectorized silver, which adds light to the engine bay and makes everything look pretty cool.)
Awesome project, though. I'm jealous of your vram torque curve already. |
man oh man... i'm getting displacement envy... that thing will scoot!!!
That looks nasty. Very, very nasty.
Rob, I'm curious about the aeroquip in the back ground. Did you do something different or just replumb stock?
Mike, I guess it is just personal preference. I had a cone at one time on my engine as well. I think the stock filters are way better than any aftermarket cone. IMO, a K&N filter ruined a Bultaco engine I had. I have no interference with the airbox. It is however extremely tight. |
On the heat tube, sopme to you have to stick a 4x4 or ? in the hole and move it forward so tube will fit easy!!! they bend easy, looks great, Kevin
| All times are GMT -8. The time now is 03:00 PM. |
