-   -   3.6 vram install & 915 rebuild progress report (http://forums.pelicanparts.com/porsche-911-technical-forum/147619-3-6-vram-install-915-rebuild-progress-report.html)
MuffinMan 02-19-2004 03:40 PM
I should find out sometime on Friday what they ended up doing with heat. A friend of mine is headed there on Saturday, and I'll ask him to take some shots from underneath and from above. Are there any specific areas you'd like a picture of?
47silver 02-19-2004 04:55 PM
Whoa
i am getting the itch i think....
nice.
gary
ischmitz 02-20-2004 06:23 PM
Rob,
my major concern is whether the big cast aluminum pipe was installed when you guys had the TRIAD exhaust fitted. It's that big piece running along the rear under the sheetmetal. It feeds the heat exchangers. I think a simple Yes or No answer is all I need.
If you take pictures it would be nice to see how the routing of the soft pipes was done if you guys are already at that stage.
BTW: I agree the tip location is a bit sagging for your valance. Dave is apparently working on that.
MuffinMan 02-21-2004 09:28 AM
They didn't get the car started yesterday due to changing the approach to an oil inlet tube fitting. A friend of mine is at the shop as we speak, and he'll take many pictures of the setup. I'll also shoot over an email to ask specifically about the stock 993 heat pipe & get back to you as soon as I hear.
MuffinMan 02-21-2004 11:33 AM
A friend of mine was at the shop today, and he took some pictures of the current state for me. I do not yet have a definitive answer about the stock 993 heat pipe, but you can see from the pics that they are using flexible pipe. This leads me to believe that they couldn't use the 993 piece, but I will confirm on Monday.
Do these pics answer your questions, Ingo? Also, let me know if you want a higher resolution version of any of these pics, and I'll email them over to you (give me your mailbox file size limit).
rfusi@gtc-motorsports.com
http://forums.pelicanparts.com/uploa...1077391972.jpg
http://forums.pelicanparts.com/uploa...1077391992.jpg
http://forums.pelicanparts.com/uploa...1077392006.jpg
http://forums.pelicanparts.com/uploa...1077392024.jpg
MuffinMan 02-21-2004 11:35 AM
http://forums.pelicanparts.com/uploa...1077392058.jpg
http://forums.pelicanparts.com/uploa...1077392067.jpg
http://forums.pelicanparts.com/uploa...1077392078.jpg
http://forums.pelicanparts.com/uploa...1077392088.jpg
mjshira 02-22-2004 10:27 AM
more p0rn please! :-)
looks great man! What are you running trans wise?
James
MuffinMan 02-23-2004 05:41 AM
I'm running the last genearation 915 magnesium case (I don't remember the model offhand).
As far as the stock 993 heat tube, my shop said, "We had to fabricate. The stock aluminum tube was not even close. We should be finishing that today".
ischmitz 02-23-2004 07:42 AM
Hm Rob, could you ask the guy at the shop where the interference was. Was it the Triad muffler or something else? I have seen Mike Feinsteins 993 conversion in pictures and he is using the stock pipe. So that makes me wonder where exactly the issues where with your car.
Thanks,
Ingo
MuffinMan 02-23-2004 09:02 AM
The only interference was with the muffler, itself.
Moses 12-21-2004 06:43 AM
Originally posted by Bill Verburg
There are several of us that would like to have a diagnostic port. AFIK only Moses has had one successfully installed and his shop apparantly doesn't wish to share the secret. You will be #2
Old news, but in case you missed it.
http://forums.pelicanparts.com/showthread.php?s=&threadid=150218&highlight=diagno stic+port
zl0ca 11-24-2014 12:50 PM
amazing work!!
winders 11-24-2014 01:25 PM
Originally Posted by zl0ca (Post 8368756)
amazing work!!
Seriously? In a month this thread would have been dead for 10 years.....
