johncj8989's Avatar
Compression question
Is a dry compression reading in the 128lbs range normal for a motor that has been rebuilt and only started a couple times? I was thinking the numbers are a little low but maybe that could be explained by the fact that the new rings have not been seated yet.
Chaos, panic and disorder . . . my work here is done
Current Stable:
Maserati GranTurismo S
Range Rover Autobiography
Various Porsches ~ in pieces
Old 02-07-2004, 05:33 PM
pjv911's Avatar
Send a message via AIM to pjv911
It is very normal to have lower than spec compression on a fresh engine. Even more so if the engine was tested cold. However it would be hard to guess since we could be talking about your lawnmower going by your description. In any case if your compression is even within 5-10% I would suggest that you have no problems there. If some are lower by a larger margin then you should do a leakdown test which may show a tight valve.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 02-07-2004, 09:11 PM
johncj8989's Avatar
Thanks curt. But I must report that my Porsche Badge sporting beast of a mower is in need of a total rebuild.
3.6 mower conversion perhaps?
Current Stable:
Old 02-07-2004, 10:16 PM
3.2 CAB's Avatar
Sounds about right for a fresh engine. Should get better after everything seats and seals in.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 02-08-2004, 12:10 AM
