canna change law physics
red-beard's Avatar
Question Dist to use with 2.7RS
As I started final assembly of my 2.7 RS spec motor (S cams, RS P&C,2.7 crank), I found the mechanical advance dist cap is cracked. It's a Marelli and it was setup for a 2.0T. I have a 2.7 vac adv dist, a Bosch. Will this work? Am I better off with something else?
James
James
Red-beard for President, 2020
Old 02-11-2004, 09:20 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
red beard,
which case do you have? the 2.0's and 2.2's had a different size dizzy hole than the later cases. You'll probably need a recurved 2.2 bosch dizzy (I have one that I won't be using) if you're still using an older case.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 02-11-2004, 09:30 AM
red-beard's Avatar
It's an early case. PM me with details of the dist you have.
James
James
Old 02-11-2004, 10:00 AM
red-beard's Avatar
I'm having trouble replying to your PM. Deal Sounds OK. Click on the yellow rectangle next to my name to send me an e-mail.
James
James
Old 02-11-2004, 12:57 PM
Tim Walsh's Avatar
I've replied
Tim
1973 911T
2005 VW GTI
Old 02-11-2004, 01:12 PM
