Fuch 6/7 offset
Can someone tell me the offset for 16" fuchs. I have the 6" front and 7" rears and I'm looking at fims with an offset of 52 mm so I want to know what size spacers I would need to factor into the cost of the new rims.
Thanks for your help. The fuchs are factory standard on a 82 SC.
Michael
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 02-11-2004, 11:22 AM
KTL KTL is online now
Schleprock
KTL's Avatar
16x6 Fuchs offset is +36mm
911/930 & 951 (looks like a 16x6 w/countersunk lug holes) 16x7 Fuchs offset is +23.3mm
Kevin L
'86 Carrera "Larry"
Old 02-11-2004, 11:39 AM
Thank you very much.
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 02-11-2004, 11:52 AM
Bill Verburg's Avatar
Kevin is right, but there is a more complete list
here
Bill Verburg
Old 02-11-2004, 12:23 PM
So then, for 52mm offsets, I would need the following minimum spacers agreed?
Front: 52 - 36 = 16 mm =>> .63"
Back: 52 - 23.3 = 28.7 mm =>> 1.14"
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 02-11-2004, 02:56 PM
Not exactly, the wheel width also is a factor.
If the +52mm wheel is also 6" wide yes, it needs a 16mm spacer but if the +52mm wheel is 7" wide then the correct o/s is ~+24mm which means it wants around a 28mm spacer.
Bill Verburg
Old 02-11-2004, 03:04 PM
You are correct in your assumption that the front is 7". How did you come about your formula to know how much more offset to add?
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 02-11-2004, 03:46 PM
If you understand what o/s is everything else is simple arithmetic
Bill Verburg
Old 02-11-2004, 03:51 PM
Thank you so much. Excellent diagram.
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 02-11-2004, 08:13 PM
Since my rear tire to be is 8" (currently 7"), then I would assume that I need a ~37 mm spacer? Don't have my calculator handy but that seems like a pretty big spacer for the rear. It's a street application but am I pushing the bounds.
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 02-14-2004, 12:15 PM
Assuming the 8" wheel has the same +52mm o/s then you need a 41.4mm spacer in the back becaise correct o/s there for an 8 is 10.6mm. Yes, that is quite large
Bill Verburg
Old 02-14-2004, 12:23 PM
