Whats in Engine Re-Seal?
Is this what is normally meant by 'engine re-seal' for an 73 E with MFI:
Front main seal Rear main seal Cam seal (MFI) Oil Pressure sender seal (crush washer) Valve cover seals MFI seals (side covers and control rack plug) Cam cover gaskets Sump cover seal Oil Cooler seals Thats about all I can think of w/o removing heads or opening case. Or is engine re-seal a term for doing whatever is necessary to stop oil leaks, such as replacing oil return tubes, head gaskets, open case halves and re-seal. |
I, personally, would include oil return tubes (if they are leaking), but not split the case, or the heads.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
does anyone have experience with the crank sleeve that supposedly allows rear main to seal good in older engines. I guess the crank in older engines develops a groove where oil seal rubs it that cannot otherwise be sealed.
Does the sleeve work? Also, if the rear main seal is part of 'engine re-seal' then trans input shaft seal should be part of it as well. At least on post 72 trans. |
