CEO CEO is offline
CEO's Avatar
Send a message via AIM to CEO
Exclamation Diff between Early and late SC intakes
I need to know what all the differences are between the early and late (lambda) Intake systems. And why did porsche go to small intake runners on the late style?
Any info would be great.
Regards, Kenneth
Kenneth
Silver 81' Targa
Old 02-27-2004, 10:13 AM
I read somewhere, can't remember where, that the smaller intakes worked better with the higher compression of the late model SC's.
Old 02-27-2004, 10:23 AM
jluetjen's Avatar
From what I can tell, my theory is that the smaller intake diameter may have improved low engine speed running (possibly a pollution improvement) by keeping the intake gas speeds up. I haven't seen any data that would suggest that it hurt the performance at all on the 3.0s.
I'm guessing that increasing the CR could have an offsetting affect on any drop in efficiency at higher engine speeds resulting from the smaller intakes, as well as improved the part throttle performance.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 02-27-2004, 10:33 AM
Bill Verburg's Avatar
As John said the smaller ports & runners contribute to low speed torque and throttle response by keeping gas velocity up, this also sharpens and enhances any vacuum signals which might be used.
When I raced MX I had several sets od cylinders(2srk ports are in the cylinder walls)c, some with bigg high hp ports and some w/ smaller toqier ports. The track and track condition determined which was used.
Bill Verburg
Old 02-27-2004, 11:05 AM
drag racing the short bus
dd74's Avatar
So did you have to change heads along with the CIS depending on the track?
The Terror of Tiny Town
Old 02-27-2004, 11:13 AM
2 strk heads are just a lid for the jugs and a place to screw in a spark plug, single cyl. 2strks are very simple devices
Bill Verburg
Old 02-27-2004, 11:17 AM
CEO CEO is offline
CEO's Avatar
The info I have is that the 78-79 SC used 45mm runners and ports and the later ones 39mm runners and ports.
Noah where did you get your information at.
Kenneth
Silver 81' Targa
Old 02-27-2004, 12:10 PM
