Original Owner
I'm still waiting for someone to try two KO3s. They are if anything undersized for a 1.8L (ask me how I know).
And I will donate my removed KO3 to the first true builder who will build a twin 3.0L or 3.2L on the KO3 base.
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
Senior Member
Thad,
Can you give me some up close pictures and dimensions of the K03? I looked into those closely, but shied away after reading so many "ditch the K03 to upgrade to the more powerful & reliable K04" posts on the Audi & VW forums. Are they oil-cooled? Olivier
Olivier Hecht 1982 911SC |
And I will donate my removed KO3 to the first true builder who will build a twin 3.0L or 3.2L on the KO3 base. __________________ tsuter 78 911SC Turbo Targa Thaaaats Right!! I plan on building a twin 2.2 with 66mm crank and 2.4 E pistons with MFI..... You game????
Dennis H. 72 911E 2.7 RS stuff 72 911T with a 2.7(Sold 5-13-2011) 2012 Kona Blue Metallic Mustang GT Convertible 6spd 67 Mustang coupe future SVRA group 6 car 63 Falcon hardtop 302/4spd |
Original Owner
Two KO3s are probably going to be a little too big for a 2.2/2.4 liter. I'd check some other possiblities first.
Original Owner
Here is picture of the KO3 to dimensionalize it. These are for VWs mighty 1.8T but they are a bit small for anything over 200HP in single turbo applications.
Would it be plausible to twin turbo a 2.0 (with the good 73.5 7r case) with forged Mahle pistons if the compression is pushing 9.8:1? I know low boost and a cooler would be a must due to the high compression.
Ideas??? Thanks
Chaos, panic and disorder . . . my work here is done Current Stable: Maserati GranTurismo S Range Rover Autobiography Various Porsches ~ in pieces |
Thank you for your time, |
Even with a single turbo is the high compression viable or is it just too much to consider adding turbo boost?
9.8:1 sound a tad too high on two-valve/cylinder aircooled engine. You could probably boost something like 0.3 bar or so, it's probably not worth doing.
There are other cheap tricks that can be den, depending on how your pistons look like. You could turn them few mm's to get lower C/R if they are symetrical.
Andy |
As far as I can see, American 1981 SC 3.0 engine had 9.3:1 C/R. Older SC engines that had C/R of 8.5:1 should be much easier to turbocharge.
You cannot compare C/R of SAAB engine to SC engine and expect them to act similar. SAAB engine has four valves per cylinder, cloverleaf combustion chambers, centrally placed spark-plug, bowl-shaped pistons, watercooled heads and state-of art knock-detection circuitry. SC engine doesn't have any of this, so you have to run low to keep it safe. Remember that early 930 had 6.5:1 and 7.0:1 C/R! I believe 8.5:1 is good compromise between efficiency, off-boost response and durability when it comes to DIY-turbo conversions on budget using conservative boost. I wouldn't go higher than this. For extra boost, it would be wise with little less compression.
Senior Member
Thad,
Are the K03s oil cooled? I would appreciate any other pictures you may have of them from the other angles. Olivier
yes, yes, and yes.
Thanks!
Andy |
Senior Member
Thad,
Do you have any pictures of the K03s oriented like the T-25 picture I have on page 7 of this post with a ruller in the shot? I am having trouble comparing the two sizes due to the different angles. Thanks, Olivier
Senior Member
Also, I have not been able to loosen the giant snap ring on the compressor side of my turbo to clock the housing. I have used every type and size of snap-ring pliers that Sears or anyone else around has, and, even when the pliers fit, the ring does not budge.
Anyone have any suggestions or better tool ideas? Thanks, Olivier
Curious to know how you guys went with your T25's or K03 TT projects?
Mark, how about your GT28RS's? How well did they work?
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Senior Member
Mine are still waiting to go in, since I need to switch to EFI and work up the courage to boost a 9.3:1 engine htat is running well. I will probably wait until it needs a rebuild and strengthen it then before adding the turbos. It is a hard project to "get to" on a daily driver...
Senior Member
Mine are still waiting to go in, since I need to switch to EFI and work up the courage to boost a 9.3:1 engine that is running well. I will probably wait until it needs a rebuild and strengthen it then before adding the turbos. It is a hard project to "get to" on a daily driver...
Any progress 724doorE?
I live just south of you and would be interesting to bounce ideas off someone more local. I've sourced some 993TT headers already for my project. Have you moved foward yet in ideas or reality? I'm not boosting my 2.7, though.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Crotchety Old Bastard
What are you planning Luke? 993tt exchangers ain't cheap!
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
