Me like track days
Craig 930 RS's Avatar
I am NOT a 1/4 miler.......but........
What would be a guess - for reference - of 0-60 & 1/4 mile times
for my SC at 2670 lbs and 315hp 3.6 Varioram? High 12s in the 1.4 mile??
Craig
RS
Old 03-15-2004, 03:03 PM
Bill Verburg's Avatar
I seriouly doubt that you will realistically have 315hp.
Ask me how I might happen to know.
Acceleration, will be adequate. Especially if overall gearing is reasonable.
Bill Verburg
Old 03-15-2004, 03:08 PM
ZAMIRZ's Avatar
Thom took his to the track and ran a 12.7, your times will probably be in the same region depending on how much you beat the car on the launch.
Amir
'83 911SC
Old 03-15-2004, 03:12 PM
Me like track days
12.7 is damn quick.
BV - "How DO you know"?
Craig
RS
.......Varioram in near future
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 03-15-2004, 03:20 PM
Me like track days
4.7 to 60 and 12.7 in the 1/4. Gawwwwwwwwd..........
I'm at 15.2 via G-Tech right now with the 79 Euro 3.0 with 200.6 hp
Hang on time comin' up!!!
Craig
RS
Old 03-15-2004, 03:25 PM
A lot of time mispent on various dynos.
A 3.6 vram can legitamataly generate in the 290s fwhp when optimized w/ headers and chip. The factory really didn't leave much on the table.
A cam/valves can boost that to the low 300s at the expense of low speed torque which is more than adequate in any case.
Bill Verburg
Old 03-15-2004, 03:26 PM
RETIRED
Joe Bob's Avatar
I ran high 14s with my euro 3.0 in my cab....be fun to find out what the 3.6 could do....
2012 ML350 3.0 Turbo Diesel
Old 03-15-2004, 03:29 PM
Me like track days
Was interesting to see Dynojet readings on this list in the range of 268 rwhp - extrapolate this to 315hp (?) si?
Craig
RS
Old 03-15-2004, 05:13 PM
Craig,
It was my car the dyno'd 268 rwhp. I seriously doubt there is more than 300-305 at the crank. Also, a reading of 268 on this dyno might not be 268 on all of them. But...before my Varioram was working I dyno'd 224 on the same dyno.
Rwhp and torque is all that counts really. The good news is torque was above 200 ft/lbs from 3100 rpms all the way up.
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 03-15-2004, 06:01 PM
Crotchety Old Bastard
RarlyL8's Avatar
'78SC @ 2500lb
3.0L w/SSIs & no A/C
Big Ass tires + the rare perfect launch = 14.2 @ 92mph
A 3.6 should be capable of high 12's
Old 03-15-2004, 06:55 PM
There is a lot of information here on numerous 3.6 and 3.8 cars w/ and w/o mods. All were done on the same dyno by the same crew and can be validly compared w/ each other.
Here is another site w/ lots of data.. Again all data was collected from the same type of dyno and can validly be compared within the data set. Mostly 964 stuff though.
Bill Verburg
Old 03-15-2004, 07:18 PM
Cornpanzer's Avatar
This is fairly accurate if you want to play with it. Plug in estimated wheel HP and weight WITH DRIVER. Remember that this calculater is assumin that traction is not a problem.
http://www.tvwdra.org/programs/hp.htm
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 03-15-2004, 07:25 PM
sheeeet, if that don't beat all!
Just imagine what that could mean at the rear wheels - with the back end of an SC actually having a drive train!
LOL
Old 03-16-2004, 07:06 AM
D Hanson's Avatar
I read an article in one of the Porsche mags, maybe GT, about a 3.2 with the 993 transplant. They discussed varioram holding back the engine around the 300 range and at upper RPMs. They removed varioram on this car and there was mention that 400 hp could be attained with Varioram removed. Not agreeing or disagreeing, but just passing on what I read. I will be happy to find article when I get home if anyone is interested in it.
90 C2 Cab Ruf Red/Blk
03 Caynne S L.Blue/Grey
03 996 TT Blk/Blk
04 996 Atlas Grey/Blk
Old 03-16-2004, 07:44 AM
No, A vram would not be wanted on an all out race motor. The Supercups do not have it. The RSCS is the top model w/ it.
Vram is designed to enhance the midrange torque of a street motor, making it more flexible in street use at street rpm levels.
A race motor will use TWM intakes and be undriveable for most street use.
Different horses for different courses.
The vram is good for power into the low 300s and rpm to ~7300
Bill Verburg
Old 03-16-2004, 12:30 PM
If your tansmission is still the 915, I do not think you will be making many 12 second runs in your car. If you can get 315 horsepower out of your car, you should be running in the upper 12s.
Old 03-16-2004, 02:17 PM
D Hanson's Avatar
I run 12.6 and 12.7 on G-Tech in my 90. I have spent alot on my motor though and it is probably only about 300 hp for now but torque was around 240 at the wheels.
03 996 TT Blk/Blk
Old 03-16-2004, 02:57 PM
