Me like track days
I am NOT a 1/4 miler.......but........
What would be a guess - for reference - of 0-60 & 1/4 mile times
for my SC at 2670 lbs and 315hp 3.6 Varioram? High 12s in the 1.4 mile?? Craig RS |
I seriouly doubt that you will realistically have 315hp.
Ask me how I might happen to know. Acceleration, will be adequate. Especially if overall gearing is reasonable.
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 03-15-2004 at 03:14 PM.. |
Thom took his to the track and ran a 12.7, your times will probably be in the same region depending on how much you beat the car on the launch.
Amir '83 911SC |
Me like track days
12.7 is damn quick.
BV - "How DO you know"? Craig RS .......Varioram in near future
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Me like track days
4.7 to 60 and 12.7 in the 1/4. Gawwwwwwwwd..........
I'm at 15.2 via G-Tech right now with the 79 Euro 3.0 with 200.6 hp Hang on time comin' up!!! Craig RS
A lot of time mispent on various dynos.
A 3.6 vram can legitamataly generate in the 290s fwhp when optimized w/ headers and chip. The factory really didn't leave much on the table. A cam/valves can boost that to the low 300s at the expense of low speed torque which is more than adequate in any case.
RETIRED
I ran high 14s with my euro 3.0 in my cab....be fun to find out what the 3.6 could do....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Me like track days
Was interesting to see Dynojet readings on this list in the range of 268 rwhp - extrapolate this to 315hp (?) si?
Craig RS
Craig,
It was my car the dyno'd 268 rwhp. I seriously doubt there is more than 300-305 at the crank. Also, a reading of 268 on this dyno might not be 268 on all of them. But...before my Varioram was working I dyno'd 224 on the same dyno. Rwhp and torque is all that counts really. The good news is torque was above 200 ft/lbs from 3100 rpms all the way up.
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! |
Crotchety Old Bastard
'78SC @ 2500lb
3.0L w/SSIs & no A/C Big Ass tires + the rare perfect launch = 14.2 @ 92mph A 3.6 should be capable of high 12's
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
There is a lot of information here on numerous 3.6 and 3.8 cars w/ and w/o mods. All were done on the same dyno by the same crew and can be validly compared w/ each other.
Here is another site w/ lots of data.. Again all data was collected from the same type of dyno and can validly be compared within the data set. Mostly 964 stuff though.
This is fairly accurate if you want to play with it. Plug in estimated wheel HP and weight WITH DRIVER. Remember that this calculater is assumin that traction is not a problem.
http://www.tvwdra.org/programs/hp.htm
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/ 1970 911S, 10 sec 67 Beetle (300 rear wheel HP) RGruppe#252 |
Just imagine what that could mean at the rear wheels - with the back end of an SC actually having a drive train! LOL
I read an article in one of the Porsche mags, maybe GT, about a 3.2 with the 993 transplant. They discussed varioram holding back the engine around the 300 range and at upper RPMs. They removed varioram on this car and there was mention that 400 hp could be attained with Varioram removed. Not agreeing or disagreeing, but just passing on what I read. I will be happy to find article when I get home if anyone is interested in it.
90 C2 Cab Ruf Red/Blk 03 Caynne S L.Blue/Grey 03 996 TT Blk/Blk 04 996 Atlas Grey/Blk |
No, A vram would not be wanted on an all out race motor. The Supercups do not have it. The RSCS is the top model w/ it.
Vram is designed to enhance the midrange torque of a street motor, making it more flexible in street use at street rpm levels. A race motor will use TWM intakes and be undriveable for most street use. Different horses for different courses. The vram is good for power into the low 300s and rpm to ~7300
If your tansmission is still the 915, I do not think you will be making many 12 second runs in your car. If you can get 315 horsepower out of your car, you should be running in the upper 12s.
I run 12.6 and 12.7 on G-Tech in my 90. I have spent alot on my motor though and it is probably only about 300 hp for now but torque was around 240 at the wheels.
