Gordo2's Avatar
'83 SC Alternator Strap Removal
Snowy day so I decided to rip out my alternator to bead blast the fan and housing to clean it up.
Got the assembly off but I can't seem to remove the band (I would like to paint it). Does it slide out under the retainer brackets or what? Which way is easier to slide it out (toward the distributor or other side)? It seems to be wedged in place.
Also if I get it removed, how difficult will it be to reinstall. I don't want to paint it only to find that I chew it up on reinstallation.
Thanks, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 03-17-2004, 09:48 PM
bit bit is offline
bit's Avatar
Hi Gordo,
I actually removed the distributer to get mine out. Put the engine at TDC and yank the dizzy. You can then get the band out on that side. Wasn't to bad to do. Re-install after powdercoat was about the same difficulty, I re-inserted it from the distributer side and then put the diz back in, pointing to the #1 TDC mark and checked the timing.
.Steven
1980 911SC
1980 911SC
Old 03-18-2004, 01:36 AM
Gordo2's Avatar
Still Stuck, Holding Up Progress
Making headway on the fan,
Before:
After $15 bucks & 20 minutes of bead blasting (I love that machine)
But still having difficulty getting the strap off to paint.
The passenger side heater duct is removed and I would prefer not to pull the distributor. Any tips/tricks? Do I just have to muscle the thing out? I'm about 20 more minutes of frustration away from wrapping the thing in plastic and tape and painting it on the spot.
Thanks, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 03-18-2004, 06:40 PM
Slippery Slope Victim
NY65912's Avatar
I'm doing the same.....see distibutor help post. Learn from my mistake.
The distributor needs to come out, but do it in the correct way.
Mike
Mike²
1985 M491
Old 03-18-2004, 06:44 PM
UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
I had to pull my distributor to get mine out and back in, no other way.
Matt
'82 911SC Targa!
Old 03-18-2004, 07:31 PM
Gordo2's Avatar
Screw It
I hate to half A$$ jobs but this was intended to be a "simple, quick" project.
Looks like it gets painted while on the engine, or at least 3/4 of it.
Thanks guys,
Gordo
I will post how things turn out.
Don "Gordo" Gordon
'83 911SC Targa
Old 03-18-2004, 07:48 PM
It's really not that hard. Just put #1 at TDC and note the position of the roter when you pull it. I didnt even pull mine all the way out, just enough for the strap to clear it.
Matt
'82 911SC Targa!
Old 03-18-2004, 08:19 PM
Why are you so afraid of pulling the dizzy? You don't even have to time the cam to put it back.
TDC number 1, mark the dizzy anyway you like
Leave it at TDC number 1, put it back where marked.
Done.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-18-2004, 08:22 PM
Ya, what he said
Matt
'82 911SC Targa!
Old 03-18-2004, 08:27 PM
bit bit is offline
bit's Avatar
Ya Gordo, it takes about 5 min to do.
Here's what mine looks like now after powder coat.
.Steven
1980 911SC
Old 03-18-2004, 11:16 PM
Gordo2's Avatar
Painted Alternator Strap
I didn't remove the distributor. Wasn't that I was technically concerned, I've done it before on other vehicles. More concerned about how I have a tendency to try "improve ($$)" things before I reinstall them. I think some of you know exactly what I'm talking about.
Either way, here's how I painted the strap without removing it:
(I could work for Macco)
And the finished product:
I painted the fan & housing with 3 coats of high temp paint in cast aluminum color. Will follow up in a few months to provide feedback on how it holds up. Hit the strap with a high temp flat black.
Thanks, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 03-20-2004, 08:11 PM
Somatic Negative Optimist
Gunter's Avatar
Cool
Steven: I am going down memory lane when looking at your engine; had exactly the same. But now, the A/C is gone, fan blower gone, rear whiper gone, Cruise control gone, SSI's are installed and I have room to work in there. Try it, you'll like it.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-20-2004, 10:11 PM
Doug E's Avatar
Don - looks great! Where did you get the bead blasting machine?
Doug
'81 SC Coupe
Old 03-21-2004, 06:13 AM
Gordo2's Avatar
Military Perks
Doug,
Being in the military not only do I get to enjoy visiting exotic locations such as Iraq, I have access to an on base auto hobby shop that has loads of tools.
They have a bead blaster and charge $15 for 1/2 hour. Makes cleaning stuff up a breeze.
The place is pretty nice (dispite the dilapidated appearance from the outside). Has around 16 lifts, big stuff like machine presses, bench grinders, paint booth, drill presses, air tools and a nice selection of mechanics tools including stuff you normally wouldn't buy. Biggest shortfall is the lack of welders and torches.
Ever need anything blasted on the cheap I'm always open for a visit from the NoVA crew. Besides if you are creative, you can find some great roads to get down here.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 03-21-2004, 07:19 AM
kqw kqw is offline
This weekend, I used my dremel tool to polish my fan. looks good however, there are a few unpolished spots I need to get to. How does that fan come off. I noticed the "key" retainer but was reluctant to mess with it.....
The Fox
Carrera
Old 03-22-2004, 06:50 AM
kqw kqw is offline
I figured it out.....
The Fox
Carrera
Old 03-22-2004, 06:53 AM
GrindingGears's Avatar
Re: Painted Alternator Strap
Thanks, Gordo
Well how has it held up?
Your finished look is exactly what I'm going for.
Where did you get the high temp paint (cast aluminum and black)?
83 SC (gone) // 72 T (gone)
Old 05-07-2004, 12:37 PM
Gordo2's Avatar
Painted Alternator Fan, Still Looks Great
But... I haven't logged too many miles since the project (somewhere around 1,500-2,000 miles since painting). Here's a pic I took a moment ago (as is, no cleaning or touch up since I painted it):
(Note: poor lighting is responsible for the discolored look, in better light it looks like it did the day I painted it: clean, bright cast color/look).
There is a little wear along the leading edge of the fan, but only noticable if you are really looking for it. My guess is that the paint will hold up and still look good for around a year and a half.
I used VHT (brand) brake caliper, drum & rotor paint in cast aluminum color (SP-735). Can't recall where I bought it (probably Home Depot, Lowes, Wal Mart or other convient auto parts place). It's good stuff. I had it left over from when I rebuilt my rear brakes. I painted my calipers and outer portion of the e-brake drum with it. That job was 2 years ago and it has held up very nicely, I expect the same for the fan.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 05-09-2004, 09:02 PM
SP2 SP2 is offline
SP2's Avatar
Hey Gordo,
I know this is a two year old thread, but I was wondering how the VHT paint on your fan and fan housing and strap is doing. I am now thinking of using the same paint. Any advice? Your finished product looked great.
Thanks!
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 11-15-2006, 09:18 PM
Gordo2's Avatar
Holding Up
Other than being a little dirty (which you get no matter what you coat it with...), the paint is holding up fine. Will try to remember to take a pic tonight - without cleaning and with a quick clean up.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 11-16-2006, 04:39 AM
