one of gods prototypes
bell's Avatar
autometer shift light.......need adapter?
85 carrera 3.2........i have an autometer shift lite with the built in rpm pills that i need to wire up.......
will i need a tach adapter or can i go right to the tach wire in the dash? reading the msd threads got me thinking if i need this or not.
thanks
Brought to you by Carl's Jr.
Old 03-18-2004, 06:42 PM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Do you run an MSD or Crane Ignition???
If so take the green wire from the MSD or Crane and connect to the Green wire on the Shift light. Otherwise I think you will need the tach adapter.
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 03-19-2004, 02:25 PM
bell's Avatar
i'm not using an aftermarket ignition.....basic DME
anyone else agree that i need the adapter?
Old 03-19-2004, 04:34 PM
armandodiaz's Avatar
I'm hooking up the same one. The directions say to hook up the green wire to the negative side of the coil. I'm trying to avoid running a wire the length of the car. So far I've narrowed it down to either the black or black/violet wire on the back side of the Tach. They go to the DME which is also where the negitive side of the coil wire is. Can anyone narrow it down any further?
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 03-21-2004, 04:42 PM
If I am not mistaken it is the Black/ Violet wire.
Mark Scott
Vintage 911 Racer
Old 03-21-2004, 08:49 PM
