one of gods prototypes
autometer shift light.......need adapter?
85 carrera 3.2........i have an autometer shift lite with the built in rpm pills that i need to wire up.......
will i need a tach adapter or can i go right to the tach wire in the dash? reading the msd threads got me thinking if i need this or not. thanks
Brought to you by Carl's Jr. |
Do you run an MSD or Crane Ignition???
If so take the green wire from the MSD or Crane and connect to the Green wire on the Shift light. Otherwise I think you will need the tach adapter.
Mark Scott Vintage 911 Racer 1967 911S 2.4L ROCKET Powered by Faragallah! www.scottassociatesracing.com |
i'm not using an aftermarket ignition.....basic DME
![]() anyone else agree that i need the adapter?
I'm hooking up the same one. The directions say to hook up the green wire to the negative side of the coil. I'm trying to avoid running a wire the length of the car. So far I've narrowed it down to either the black or black/violet wire on the back side of the Tach. They go to the DME which is also where the negitive side of the coil wire is. Can anyone narrow it down any further?
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
If I am not mistaken it is the Black/ Violet wire.
