Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
3.0 to 3.6? MM says it can be done...
check this
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2466801805
now...would that work with a 3.0? i mean..how much would you have to bore out the cases to allow for this and wouldnt that cause that area to be weak and become very very scary?
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 03-18-2004, 01:40 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Anything from MM should be avoided dude. Those are byrol cylinders, which as i understand it were used in the very early motors before porsche went to aluminum cylinders with ausil and nikasil coatings.
Plus they don't list machined work in order to except the 101mm bore (however extensive that may be).
Why not get those new cylinders that pelican carry (can't think of the name off the top of my head)? They seem to have a strong backing and are a little less than mahle cylinders. Couple that with a set of custom JE pistons and you've saved some money over mahle stuff.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 03-18-2004, 03:34 PM
Administrator
Jack Olsen's Avatar
If MM jumped off a cliff, would you?
Old 03-18-2004, 03:35 PM
B D B D is offline
B D's Avatar
No, but if they rebuilt my motor I would throw it off a cliff!
68 911L
Old 03-18-2004, 03:43 PM
Sports Purpose 911 Driver
mjshira's Avatar
Ha! Jack, always nice to be able to count on you for the succinct point well made!
It sure seems that MM has a bad rep on this board.
James
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 03-18-2004, 04:13 PM
Black and Blue
Kemo's Avatar
Jack,
i was chased off a small cliff by a chow when i was a kid! Thanks for rehashing painful childhood memories!
Ive heard of the 3.2 kit for the SC (Max Moritz), but not a 3.6...
ill keep rooting around. 1fastredsc , ill check PP's P/C kits...
Prolly easier to buy a 3.6! Ruf Bumpers first...then the sport seat recover...then the carpet...then the new dash...then the tranny rebuild...im sure by then ill have something else )
Kemo
Old 03-19-2004, 10:04 AM
B58/732
BlueSkyJaunte's Avatar
Isn't the 3.0->3.2 a short-stroke?
ΜΟΛΩΝ ΛΑΒΕ
Old 03-19-2004, 11:19 AM
Black and Blue
Kemo's Avatar
blue...
yah...the 3.2 kit is basically bigger pistons and cyls to get the displacement there. the stock 3.2 got the displacement from changing the stroke and i believe the p/c for the 3.2 and 3.0 are the same diameter.
Kemo
Old 03-19-2004, 12:04 PM
Bill Verburg's Avatar
Here's the kit Andial used to sell. Note the price? It made more sense to buy a used engine.
Bill Verburg
Old 03-19-2004, 01:14 PM
