Elombard's Avatar
Which bushings best to replace first?
If you have to choose which bushing to replace first with monoballs; I wonder which would be most beneficial?
Bananna Arm Bushing (my Pick)
Strut Top
Front control Arm
Rear Spring Plate
I can really only justify doing one at a time (DIY). luckily I enjoy doing my own alinments or I would get killed on the labor etc.
What do you think?
I will probably go with the Elephant Racing products unless I can find a real deal on used stuff.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 03-24-2004, 02:10 PM
KTL KTL is offline
Schleprock
KTL's Avatar
I think the order you have there is the way i'd rate them.
The banana arm is ripe for them i'm sure. The strut top is not necessary for a street car IMO. Monoballs on the last two could make things pretty harsh.
Kevin L
'86 Carrera "Larry"
Old 03-24-2004, 02:19 PM
Elombard's Avatar
Good point Kevin, I am sure mine are shot. I was thinking of the brass bushings with the grease serks that Chuck sells for the Spring Plate/ inner front control arm.
Old 03-24-2004, 02:47 PM
jyl jyl is online now
jyl's Avatar
Seems like unnecessary work to take apart the rear, then the front, then the rear, then the front. I'd do one end, then the other.
Old 03-24-2004, 03:15 PM
CHILI's Avatar
Rear Spring Plate if you can only afford one. I'm sure the stock ones are toast. So far my Netrix feel great, but if I had to do it over again, I would go with Chucks' stuff.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 03-24-2004, 03:30 PM
Craig Roche's Avatar
I just did mine and it seems like if you do the banana arm bushings you might as well do the spring plate bushings. You have to take the banana arms all the way out to get at the bushings and once you got it that far apart, well.....
Through much searching this board, I went with OEM banana arm bushings and Elephant Racing poly bronze on the spring plates. I have not put the bananas back in yet, It will be awhile before I get to "feel" the difference.
Have fun, those things are kind of a b****!!!
Craig
1984 911 Targa
Old 03-24-2004, 03:39 PM
Elombard's Avatar
Craig, I would of suggested the bannana arms for sure because they are binding by design. My car came with poly spring plate bushings so they arent worn real bad but they do squeak.
I really did not have an order in mind but If I did I guess it would be:
Banana
Rear spring plate
front cross member
upper strut
Rear spring plate
Old 03-24-2004, 03:51 PM
KTL KTL is offline
Schleprock
KTL's Avatar
I certainly agree that doing them one at a time is not cost-effective. Do them all and be done with it. One alignment needed.
As far as the rears torsion bar bushings go, i'd rate them
Neatrix
PolyBronze
PolyGraphite/Urethane
Reason being, the Neatrix are a simple install, they're cheap and they work good. Just make sure to clean the spring plate well enough to make the superglue stick. The PolyBronze are the ultimate, but more expensive. The PolyGraphite/Urethane don't fit well all the time and have no provision for greasing if they start to squeak.
I think the monoballs for the rear (especially the teflon-lined ones) are the way to go because they provide the best free movement. And they're not much more expensive than the four OEM replacement rubber bushings.
Like I said, I think the front monoballs are overkill for a street car. These front strut mounts don't seem to wear out nearly as much as any of the other bushings on the car. Mine were fine after 14 yrs. of age. If you do want to replace them, these guys have a neat alternative to OEM rubber (very expensive) and the monoballs:
Tarret Engineering Poly Strut Bushings
Not sure if they are similar to the rear banana arm polys (can cause binding), but I doubt it.
Kevin L
'86 Carrera "Larry"
Old 03-25-2004, 06:46 AM
jyl's Avatar
Are the "polybronze" bushings on the Tarret Engineering website the Elephant Racing ones? Or are they knock-offs?
http://www.tarett.com/bronze_susp_bushings.htm
Old 03-25-2004, 07:31 AM
Chuck Moreland's Avatar
They are not knock offs. Polybronze is a patent pending design manufactured by Elephant Racing and available through Pelican and other channels.
Chuck Moreland - elephantracing.com - vonnen.com
Old 03-25-2004, 07:39 AM
