RX7 RX7 is offline
How to: Tell a rebody or the real thing?
Looking at the exterior. How would one tell the differance between a older rebodied 911 (993) or the real thing?
It seems alot of people are choosing this route instead of spending the big money for the real thing.
1993 RX7
503 whp
2350 lbs
Old 03-29-2004, 09:31 AM
Hilbilly Deluxe
emcon5's Avatar
Look through the windshield at the VIN in the A pillar.
Look under the car at the suspension. Torsion bars=89 or older.
Tom
82 911SC Coupe
GTI Cup #43
Old 03-29-2004, 10:25 AM
techweenie's Avatar
The VIN is definitely going to tell you, but if it's not there (and I've seen plenty of cars where the A pillar VIN plate was absent), there's another way:
None of the kits deal well with transitioning the older tub to the newer hood line. The 993 hood doesn't drop as far as the older car, so with the front hood open, you'd see the ledge for the trunk gasket dropping away from the hood mounting surface..
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 03-29-2004, 10:37 AM
Administrator
Jack Olsen's Avatar
Typically, the spacing between the windshield wipers is wrong, too.
As 993 prices drop, I think the market for these kits is going to start to dry up.
Old 03-29-2004, 11:02 AM
The conversion pieces on the rebodied car are most likely going to be fiberglass.
Warren & Ron, may you rest in Peace.
Old 03-29-2004, 11:11 AM
techweenie's Avatar
993 C2S Speedster
I owned this car last Summer. All-steel conversion (plus 930 engine & G50 conversion) that cost the prior owner a rumored $50K.
Chassis was '77 Targa.
1969 coupe hot rod
Old 03-29-2004, 11:22 AM
Also read the section of Bruce Anderson's Porsche 911 Performance Handbook on buying a used car (Chapt 2, I think). It describes a check to see if it is likely if a car has had a fender replaced or repaired (check the inside of the fender lip for texturing). Chances are only original Porsche body work has that texturing (assuming the new Porsches still have the texturing).
Old 03-29-2004, 12:04 PM
nostatic's Avatar
Sawzall. Talk to Mikez or Zeke for details...
Old 03-29-2004, 12:21 PM
RX7 RX7 is offline
I wasn't sure if the exterior dimentions were different than the original 993's?
Don't those conversions have to be molded (Bondo'd) onto the original tub?
1993 RX7
503 whp
2350 lbs
Old 03-29-2004, 01:45 PM
Senior Member
Leland Pate's Avatar
The windshield wipers are usually a dead give away.
And the placement of the windshield washer nozzles.
Chief Architect and Mastermind,
SCWDP
Old 03-29-2004, 01:53 PM
RX7 RX7 is offline
Does anyone have pictures of the two fake and real windshild wipers just for reference?
1993 RX7
503 whp
2350 lbs
Old 03-29-2004, 01:56 PM
RX7 RX7 is offline
Anyone?
1993 RX7
503 whp
2350 lbs
Old 03-30-2004, 05:08 AM
Send a message via AIM to tkrefeld
Ols style ipers can be swapped out for the 993 style..
Old 03-30-2004, 06:08 AM
