konish's Avatar
SC rev limit rotor
Fellas,
I tried searching and after reading about 50 different threads with the words, SC, rev, limit and rotor I still haven't been able to locate the part number for an SC rev limiting rotor. About a month ago I had quite the scare when my throttle stuck open. Anyway, I was able to piece together that our host does not carry these (I suspect Euro part), and Vertex does, although I cannot find it on their site (way less user friendly than PP). Anyway, does anybody have a lead on these? Looking for one between 6000-7000 rpm...
R/
Dustin
Old 04-05-2004, 06:48 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
You have to call Veterx, and they are the only ones that I could find that have it. I didn't have the part number, but told them the year of my car and what I wanted and they knew exactly what I was after. For my car, I got the 6800 rpm one, and it works very nicely. I'll look for a part number on it in a little while if you can wait.
1981 SC ROW Coupe
Old 04-05-2004, 06:56 PM
Go Speedracer, go!
Sorry, I was not able to get a part number. Actually I wasn't able to get the damn rotor off of my dizzy, and didn't want to break the rotor doing so. Did you have any luck finding the part? There is some info in this recent thread, where I posted pictures of my rev-limiting rotor while I was trying to get it off.
1981 SC ROW Coupe
Old 04-06-2004, 06:20 PM
konish's Avatar
Thanks for the try...I'll vertex and order one...
Old 04-06-2004, 06:34 PM
Erakad's Avatar
Still have the box from when I replaced mine...believe it's a 6800 RPM model. Part # is 930.602.901.02. Not sure of the etiquette if our host doesn't carry the part, but I got in touch with a Porsche dealer in Charlotte that had a connection.
I do think it would be cool though if Wayne would carry some of the Euro parts...I see enough Euros in the posts that a few of the common parts would really help us out.
Rob
Black 1983
911 SC Coupe
Old 04-06-2004, 07:10 PM
Send a message via AIM to fintstone
Wayne lists that number as a special order part..are you sure he can't get it?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 04-06-2004, 07:22 PM
Go Speedracer, go!
That's interesting. I called Pelican before I called Vertex to order mine. The person I talked to had no idea what I was talking about and said he couldn't get it. Then again I didn't have the part number either. Next time, I will give Pelican a try if they can get it. ($21 at Vertex.)
1981 SC ROW Coupe
Old 04-06-2004, 08:12 PM
Elombard's Avatar
I got one from TRE. Its a 930 part I think.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 04-06-2004, 08:53 PM
Eugene at Pelican Parts's Avatar
I'm at home right now so I can't verify with the database, but I'm pretty sure the 930 part cuts out at 6500 instead of the desired 6800 that the Euro rotors do. These are usually available.
As for the Euro rotors, the last time I checked, there was only one of them available in the United States through Porsche. However, we can probably special order them from Germany, but that would (A) take a while and (B) perhaps not be very cost effective. Is there really a profound interest in these? I will try to find out as many details as I can.
Eugene (Formerly) at Pelican Parts
Pelican's E-Commerce Guy, 2003-2011
2001 330i Sport
1983 911SC Coupe (sold)
Old 04-06-2004, 10:02 PM
Lots of mid-year cars with SC US 3.0 engines and no rev limiter. Might be a market. Any that go higher than 6800?
Old 04-06-2004, 10:14 PM
Early_S_Man's Avatar
Porsche Crest
--.02 is the Turbo rotor ...
930.602.901.01 is the ROW SC rotor, 7000 rpm per the spec book!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-07-2004, 08:01 AM
Thanks Warren!
Old 04-07-2004, 09:00 AM
The rotor that was on my car was a Bosch p/n 1234 382 240 set @ 6800 rpms. Anyone have a cross reference between Bosch and Porsche part numbers?
John Adams
1980 ROW 911SC
Old 04-07-2004, 09:59 AM
What does it take to install the rev limiter? Is it just a matter of swapping out the rotor?
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 04-07-2004, 10:05 AM
Eugene
Warren shows the .02 as the tubo rotor, your catalog shows the .01--could you check the numbers?
Didn't the early RS have a much higher redline? What about those rotors?
Old 04-07-2004, 01:33 PM
Mike-
Yes, it's just a matter of swapping rotors. The rev-limiting rotor is a bit larger and (obviously) has more small parts.
Old 04-07-2004, 01:45 PM
Go Speedracer, go!
For non-turbos (not sure about the turbos), the distributor changed size in '78 I think. I'm sure someone will correct me with all the specific sizes, years, dates..... I purchased a rev limiting rotor locally for a '76S and it was too small for my SC. The car still ran, but not very well because the spark had to jump a few extra mm's. The one pictured in the Pelican catalogue that Warren listed looks like the one I bought for a 76S. I'm probably wrong about something there, but worth mentioning.
Here is mine for reference:
1981 SC ROW Coupe
Old 04-07-2004, 01:52 PM
Eugene
.01 is the 930 rotor up until 1985.
.02 is the ROW SC rotor that you guys are looking for and is rather scarce in America. I'm still researching its availability.
Rev-limiting rotors for early 911s (although readily available in the States) will not fit SC or 930 distributors.
2001 330i Sport
Old 04-07-2004, 02:40 PM
Originally posted by JP911
Mike-
It fits under a normal cap? Why is this euro? What was on the American cars?
1979 911 SC Targa
Old 04-07-2004, 02:46 PM
Porsche Crest
Here is the '72 - '77 rev-limiting rotor ... smaller OD!
Warren Hall, Jr.
Old 04-07-2004, 02:47 PM
