Originally posted by thrown_hammer
Well heck with it. i am taking tommorow off and giving her the whole 9 yards! When you see me next I will have a shiny pastel blue easter egg. Have a good Easter and I will see ya on the flipside.
Whoohoo!
Borrow an extra fan to blow air in the left window to keep the air outside of the booth from going stale and loading up with boom-boom!
expecting pics very soon
Charlie Baer
'79 Euro 911SC (Guards Red)
'83 Quattro (Mars Red)
Old 04-06-2004, 04:54 PM
Wow, What a bunch of dooms day fans,. Iv'e shot paint in a shop many times with a non-vented, open flame heater, and never had any kind of problem. While shooting primer, don't worry too much about keeping it so super clean, keep that effort for the paint. You DO want to use a good charcoal respirator though, and keep it in a sealed container (zip lock bag) when not in use. They are only good for about 35 hours. Use a good catylized primer or you will see die back after you apply your paint.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 04-06-2004, 05:14 PM
Originally posted by toolman
..Iv'e shot paint in a shop many times with a non-vented, open flame heater, and never had any kind of problem.
Same here, and many people can say the same until the day they die...or learn to fly as previously described
Although in a huge quonset during winter those big turbo heater tubes are nice!
Charlie Baer
Old 04-07-2004, 11:02 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Must be having fun!! Anyone heard from Shawn lately??
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 04-07-2004, 08:29 PM
notmytarga's Avatar
I enjoyed reading this thread because it brought up many issues that I encountered - so far - on my project. I am block sanding primer with 400 grit in preparation for sealer.
I bought a gallon of paint today. Final decision - (not one of the recent choices ) - Marine Blue Metallic.
This picture shows my paint booth. I hung plastic from the ceiling. I wanted to filter the air and filter the exhaust to catch overspray and keep the booth as clean as possible. I put a box fan in the window and used a tube of plastic to run the air to the filter hanging in the plastic. The other filter gets its flow from a pedistal fan I run when actually spraying. I draped plastic over the inside surface of the garage door and taped a sheet to cover the opening at the top when the door is open about a foot. I set up about 6 feet of filters along the bottom of the door opposite where the filters are when the fans are running. It has been up about three weeks and I will need to "resanitize" the booth before spraying color.
The masking paper tree with full 1000 ft rolls of 6,12, & 18 inch paper and tape was $130 total.
This garage has no furnace, water heater, dryer etc to pose a risk of flame ignition. If it did the pilots would be turned off. Our gas dryer is through the plastic and on the other side of an exterior grade door, but I will shut off the gas supply on spray -day.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 04-07-2004, 09:33 PM
thrown_hammer's Avatar
Well I spent a total of 19 hours in the garage the last two days! I consumed a case of mt.Dew and here we are today....
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 04-08-2004, 04:04 AM
And here we are putting her to bed until I can get out there and wetsand.
1975 911S (sold)
Old 04-08-2004, 04:06 AM
I had an issue with the paint gun. I was running it at 10 PSI because the gun says 10PSI max. KurtV to the rescue. He reccomended 35 PSI at the gun and that did the trick. I have a new found respect for the bodyshop guys....They earn their money.
1975 911S (sold)
Old 04-08-2004, 04:12 AM
Friend of Warren
Shawn, looks great! Now get some rest.
Kurt V
Old 04-08-2004, 05:39 AM
notmytarga's Avatar
Looks good - get alot of 330 paper.
I have had more success each time I have used primer as I learn more about my gun. 10 PSI into the gun doesn't cut it - big droplets and lots of runs - doesn't atomitize. My gun has a subtle 43 PSI stamped on the inlet - Targa80 is to thank for pointing this out. This is the pressure that needs to be set while the trigger is PULLED - "dynamic pressure"
Eventually I will be confident enough to shoot color!
A few links that explain this=
Painting Basics at the Auto Body Store
Poke around on this site - Sharpe Guns
Good Luck
Old 04-08-2004, 05:49 AM
Thanks for the links. I will be reading up. My primer was a primer/sealer so the next step is color. Need to let my fingertips heal a bit before any more sanding.
1975 911S (sold)
Old 04-08-2004, 06:00 AM
}{arlequin's Avatar
that last pic is really cool... like some skunkworks project in an x-file-ish sort of way
dave
1973,5
Old 04-08-2004, 06:10 AM
LOL! I know. My wife told me she was waiting for the MIB to show up.
1975 911S (sold)
Old 04-08-2004, 06:14 AM
atlporsche's Avatar
you should just clear over the dark grey primer...that's a neat color.
sjd
Porsche sold, moving back to muscle cars for a bit.
Old 04-08-2004, 07:38 AM
If you used a primer/sealer and let it dry more than 12 hours, you will have to scuff sand it with 600 for the proper adhesion to take place. It's probably a good idea to give it a little scuff with 600 anyway to remove any surface imperfection, your color will only amplify the contours of the substraight. Use a tack cloth just before painting to pick up any sanding dust. Looks like you are doing a great job, good luck. Let us know if you need help recomending a good micro sand and buff system.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 04-08-2004, 07:41 AM
I am gonna wetsand on Saturday. Its still cool here overnight so I am giving it plenty of time to dry. I will spray color as soon as mother nature cooperates. Looks like a week or more away.
1975 911S (sold)
Old 04-08-2004, 09:19 AM
Administrator
Jack Olsen's Avatar
4/8/04 - Updated the subject of the thread.
It's looking GREAT!
Old 04-08-2004, 09:39 AM
Thanks for the update on the title Jack.
I am getting antsy to put some color on her! Maybe I will paint some hotwheels or something to tide me over....
1975 911S (sold)
Old 04-08-2004, 09:48 AM
frogman's Avatar
Wink
It's lookin great Shawn. Be sure to check the passenger seat for overspray, I can't wait to make use of your newly aquired skill.
I can see it now.....STEALTH FROG
BWAAHHAAHHAAHHAAHHAA !!!!
GruppeB panzer Div. #928"
80 928-"The Black Frog"
My car only has to impress one person.......ME !!!
Old 04-08-2004, 02:15 PM
Just to give you one more tip along the lines of Kurt, That 35psi is at the gun with air flowing through it (full trigger pull). On a 50 ft hose it is very possible that this may require the outlet of the compressor to be near 100-120psi. Also, I would suggest you put a disposable filter on the inlet of your gun to dry the incoming air for the color and clear.
Dante Oliverio
Old 04-08-2004, 03:07 PM
