johncj8989's Avatar
Question 915/23 clutch disk question
I am mounting a 915/23 tranny from a 912E to a 2.0 six. The 915/23 is essentially a 915 with an early 901 mainshaft. So I assume that I can get a clutch disk for a 901 and it will fit ok???
I didn't know for sure if there were any other differences in the spline that would create problems.
Can anybody clarify for me??????
Chaos, panic and disorder . . . my work here is done
Current Stable:
Maserati GranTurismo S
Range Rover Autobiography
Various Porsches ~ in pieces
Old 04-05-2004, 09:39 AM
johncj8989's Avatar
Current Stable:
Old 04-05-2004, 03:27 PM
the fork and t/o bearing are peculiar to the 912E also, but may well work with the early pressure plate, as long as the spacing is close. the 901 disc is smaller diameter than a 915 disc, but you're using the original pressure plate, so it may bolt on without a hitch. never tried it, but sounds possible.
206 637 4071
Old 04-05-2004, 04:09 PM
