jluetjen's Avatar
Question Front Axle Seal Orientation
OK guys, this is one that I always forget in the time between whenever I have to replace a seal on the car.
When installing the axle seals, which side is in? The gasket makes a < around the perimeter with a spring mounted on the inside of the open portion of the < I'm assuming to keep pressure on the shaft that runs through the center. Which way does it go?
A) < grease
B) > grease
Thanks.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 04-06-2004, 04:20 AM
IROC's Avatar
I don't fully understand your ">", but the seal is installed such that the "open" part of the seal is facing the hub. That is, the smooth, outer portion faces out. Makes it easier to tap in with a hammer. :>)
Make sense? Probably not. This one of those things that is surprisingly hard to describe using only text... :>)
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-06-2004, 04:34 AM
jluetjen's Avatar
Thanks. So the side pictured below faces the hub and in towards the grease.
(Thanks to the Pelican on-line catelog for the picture.)
John
'69 911E
Old 04-06-2004, 08:39 AM
IROC's Avatar
Yep.
Mike
Mike
1976 Euro 911
Old 04-06-2004, 09:43 AM
