what is t h a t ?????
i bought it from e bay,it should be from a 911. but what year is that? how many degrees does the temp gauge messures? and what senders do i have to put? if i'll put a universal vdo oil pressure sender(for 150 psi),will it work? please answer me,it will help me a lot thanks |
I don't remember, I'll see if i can look it up somewhere
You might not be happier owning a Porsche, but it certainly feels so driving one |
RETIRED
Look on the back....most have a date on them.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Looks like it might be from a european car with the temp numbers being in Celcius(??) Don't know though,.....just a thought.
Brian 79 930
Brian BLK 79-930 |
"Looks like it might be from a european car with the temp numbers being in Celcius..."
Not necessarily... my (Canadian) car has the temp markings in Celcius. This gauge has no numbers at all. -MAS
77 911S Targa (current car) 87 924S (my previous car) |
RETIRED
A lot of those gauges have the oil temp along the side under the lip....check it, might be surprised. My SC has them and I take a look every once in a while to jog my memory. Kinda dumb to put them there....
Cymru am Byth
Looks like its from a 72-73 era car from the pictures in Peter Morgans book.
1986 930 (Gone but not forgotten) 1995 993 (Should Never Have Sold it) 2007 BMW 328Xi Sport Wagon 2005 Lexus GX470 Offroader Julian Williams |
Maybe I'm really confused, but it looks like the whole guage is dedicated to oil, and the numbers on the right are pressure units. The actual numbers would correlate well to PSI, not "Druck" (bar) units as in Europe, so I'm betting it's for the American market. The left side, for temps, is reminding me of that "no numbers" era in the late sixties/early seventies. The guages coloring look appropriate to that era as well. Perhaps this guage was used in the "starter 911", the 912, where Porsche engineers may have assumed that the owners would be fine with a red line and no numerical markings. Just a WAG, though!
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Why all the guessing ? the date is on the back. Also if it has mounting studs its a 68-69 gauge . If theres no studs its a 1970 -73` .
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
Could be a 916 gauge.
It's not anything you'd find in a U.S. 72/73 911.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Heres a 1969 911S gauge .
1974 911
Gon fix it with me hammer
don't think there was any green on 911 gauges in 72/73
at least not on mine also , Euro gauges, don't use psi they have temp on the left going up to 150 C and pressure on the right going 0-2-4-6-8-10
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
It's the high range of the PSI side that has me most puzzled.
I dont think thats actually green. Likely just the picture quality. I have over 300 or more early 911 gauges. And have seen that gauge in the boxes before. Its not rare or valuable. I just cant put a finger on the exact application. As with all VDO/Porsche gauges the part # is under the glass at the very top. That would be an easy way to end this confusion.
Kurt Williams
I doubt it's a 72/73 gauge.... According to "A restorers guide to authencity" by Dr. B. Johnsson no cars from 64 - 73 have a gauge with no numbers on the temprature scale...
Familycar: BMW 520i Touring -96 MY Car: Porsche 911T Targa 1972 |
dunno kurt, but the white looks white to me, so if the white's there, then that looks distinctly like green.
if the pic would have been bad quality , then my guess would be that either everything would look greenish
Stijn , you do have a point.
Kurt Williams
only the temp bars look green (as opposed to the numbers). '67 and earlier were green guages, but the numbers and bars were green.
There is a picture of a RHD '73 in Morgan's book that sorta looks like this one (numbers the same on the press side, no numbers on the temp side)...except the one in the '73 has a different looking bar setup on the temp side. |
Think that one is a mystery ? Ever seen one of these units which have a idiot light at the top of the oil temp bar ? I will let you guys ponder on this one before I tell you. Or does somebody know ?
Kurt Williams Here`s a pic of the motor from the same application. See any clues ?
