Now in 993 land ...
Swepco trans fluid vote: Did it make a difference in your 915
George
Yes noticeable, but not earth shattering. 1st to 2nd about the same, but 3rd through 5th is noticably smoother, but engine needs to be fully warmed up before it is really appreciated. Overall improvement was still worth the $38.
However, the $26.50 for the shifter bushing replacement I did about 2 months before I changed to Swepco 201(ball cup, shift rod, and coupler bushings) was a better value to improve shifting. Quincy
Quincy Fountain Valley, CA '83 SC, '13 P-GTS "Air cooled, fountain pen guy, living in a water cooled, iPhone world" Last edited by qcwang; 05-28-2004 at 12:14 AM.. |
Made no difference in mine. Back before the internet was such a great place for sharing info, I put Mobil1 synthetic in my 915 thinking it was probably the best thing to do. After hearing everyone talk about this magical "Swepco" I drained my Mobil1 and added Swepco. There was no noticeable difference.
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
19 years and 17k posts...
Big difference! When I changer the fluid for the first time, the old fluid looked like chocolate milk, thin and foamy. The old fluid was obviously "past it's prime" and the Swepco 201 was a noticeable improvement. I changed the fluid again about 6 weeks later to try and flush all traces of the old gunk out of there. Car shifts much better now, less noise and vibrations through the gearshift too!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
It's a trap...
Can't tell. Did all the bushings at the same time. All together they made a huge difference. I am going to change out the fluid again after only one month as I found a tooth the first time. Not many miles since then, but maybe enough to see if there is more pieces.
Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). |
canna change law physics
Hmmmmm. Interesting....
We need some Scientific data here....
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Me like track days
Made a difference, but only when warmed up.
Craig @RS
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
I have used both the 201 and 212 in my 83SC. I liked the 201 better.
I think that milage has something to do with how well the Swepco effects shifting. My SC had about 200,000 miles when I put the 201 in. I also replaced the bushings at the same time as well as a Factory short shift kit. |
Changing the fluid to Swepco was the first project I performed after purchasing the car - this board, of course, is where I first heard of the product. I noticed a considerable difference within the first mile I had driven. I was able to shift into first gear while 'slow rolling', gently, and with no grinding.
Daryl G. 1981 911 SC - sold 06/29/12 |
I've not seem much of a difference between clean Valvoline fluid and Swepco.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Made a slight difference. Maybe only in my head....
made no difference in my 915.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Thom,
Good point, but I really wanted to use a gearbox lubricant that was recommended by others with Porsches... All I was is "seat of the pants" experience and I am glad I used the Swepco... just my .02 worth...
Steve Wong and I tended to agree that a basic Dino oil with a small additive worked the best for us. Please see:
915 miracle juice |
For me, I made my changes incrementally and Swepco did help but he other changes were more dramatic. I will also state that the 2-3 year old fluid (Kendal) I removed did not look excessively dirty or have an unusual odor.
my car shifts like butter, and i did use swepco, but i cannot tell if it improved anything or not. i changed the tranny fluid before i got the car running. it is sweet now tho.
poof! gone |
I tried M1 in the trns for a short period of time. In normal use you will likely not notice any difference. But if you every try to shift even a little bit quickly you will not like what you hear.
Stick w/ the tried products. I am sure that there are other equally good fluids for the trans. out there. The local shop swears by CENPECO?
Binge User
I noticed a small improvement after a couple hundred miles. Since I bought two bottles, I will probable use it till I need a rebuild. But after that I will use whatever my mechanic recommends, which isn't Swepco. He says it's too slippery.
Paul |
I have never tried Swepco but I can sing the praises of MOTUL!!! When I changed my oil I decided to change the trans fluid and the brake fluid as well. The oil stayed dino but I opted for MOTUL gear 300 in the tranny and the MOTUL break fluid as well. First the breaks, the motul has a higher boiling point than the ATE super blue racing fluid and I have noticed much less fade and the pedal staying strong. The tranny fluid is amazing. Going from 1st to 2nd with the 915 is noticeably smoother and not only when warmed up. The shifting has become much nicer and it feels like it wants to cooperate better when banging out double clutch downshifts. I also drained a tiny amount of fluid out after a month to see what kind of wear was going on and I was pleasantly suprised to find only a minute amount of metal on the magnet cap.
For all you running synthetic out there the motul oil is awesome for that application as well, you go through a bit more than if you were to use mobil but the engine runs cooler and feels stronger because of it.
74 911s neverending story. two feet and a jetta for now. |
