Corner Balancing Using Adj Sway Bars
What is the "down side" of performing a rough corner balance using the adjustable drop links on my front and rear adjustable sway bars? On an otherwise stock 1976 911, this would be a lot easier than pulling torsion bars; and I'm happy with my current alignment and ride height. I know that this will produce some straight-ahead stiction in my sway bar bushings, but it should be considerably less than the friction that the bushings tolerate during normal cornering, and I wouldn't go too far in the adjustment anyway. A friend is about to invest in digital scales so I have an opportunity to play. What do you guys think? Thanks.
Howard
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 04-13-2004, 12:18 PM
I *think* you should get the car on the corner scales...and first see what you have before you make any changes.
Then... would suggest getting a large mug of your favorite warm ( cold?) drink...and sift through this BBS for "corner balance" threads.
Then.... post again with your questions
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-13-2004, 12:41 PM
Thanks, Will. I've spent the last two hours reviewing prior threads and learned a lot. However, no one addressed the possibility of modifying the balance WITH the sway bars (instead of the torsion bars), rather than disconnecting them.
Howard
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 04-13-2004, 12:47 PM
If you really think about it... I would guess it *can* be done, but you'd have the additional complication of the "non-independence" of the two sides. This corner balancing thing is difficult enough to grasp ( and do) as it is...and if you tweek the sway bars, not only would (say) loading up the RF cause the LR to load up ( as is normal)...you'd also have to worry about the inter-play left-to-right of the sway bar you're adjusting.
My head's spinning already.....
Why not see what you have first ???
---Wil
Wil Ferch
Old 04-13-2004, 12:52 PM
I will certainly see what I have to start with before I fiddle. In fact, it can't be too bad because the car autocrosses great; left, right and straight, braking and accelerating. If I do any adjusting at all I will limit it to 20 pounds max change on any wheel.
Howard
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 04-13-2004, 01:00 PM
911ctS's Avatar
Send a message via Yahoo to 911ctS
If you have any pre-load in your sways when your done with the corner balance then the car is going to be madly unpredictable when cornering. If you are talking about setting the car perfectly level and then purposely preloading the sways in order to get a corner balanced car, I dont believe that is possible. Or if it is, Im not aware of the benefit.
ADD: actually now that i really think about it.... it would be possible but what about the times when you catch air hauling as$ down that b!tcthin country road. Wouldn't it screw with the mid-air rebounding of your suspension.
_____________________________
Clint Smith
www.RebelRacingProducts.com
1970 911T ----> RGruppe RS/R (mexico blue)
1995 993 becoming an RS (gran prix white)
Old 04-13-2004, 01:10 PM
PRO Motorsports
Tyson Schmidt's Avatar
Pardon me, but are those "Bad Idea" jeans you're wearing?
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 04-13-2004, 04:17 PM
CHILI's Avatar
Your fronts are adjustable with just the screws on the T-bar end plates. No need to mess with the adjustable sway bars. So, that's easy, and the correct way to corner ballance. As for the rear, do you already have adjustable springplates? They weren't offered in 76, but maybe a PO already did the upgrade (as I have). If not, then I wouldn't mess with them.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 04-13-2004, 04:30 PM
Thanks, all, for your comments. Chili, I don't have adjustable spring plates, but your suggestion about the screw adjusters on the front t-bars is a good one----just as easy as purposely preloading an appropriate sway bar. I'm still not convinced that there is a functional difference between a t-bar adjustment and a sway bar preload to improve corner balance.
Howard
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 04-13-2004, 04:44 PM
Navin Johnson
TimT's Avatar
Bad Idea...bad bad bad...
OK so you preload the suspension when the car is in a static position sitting on the scales...you get the corner weights where you want them...
No go out and drive the car..
The handling will suck...
Every chassis set up guide you will find recommends disconnecting the sway bars prior to fiddling with the corner balances.
Say you preload the left front to balance the car.. ... now make a nice long right turn.... now you have not only the preload of the sway bar+spring rate +the sway bars working rate.... Turn left and all the equation becomes even wierder....
Just using the adjustment screws on the front t-bars should get you a close corner balance.....
Make sure you disconnect your sway bar beforeyou do any adjustments.
'69 911 GT-5
'75 914 GT-3
and others
Old 04-13-2004, 05:06 PM
RETIRED
Joe Bob's Avatar
If you preload the sway bar to adjust the weight balance, the shocks and tbars will end up have an uneven load on them and give different rebound charactristics....car will handle like moose and squirrel on quaaludes...
Balance the car with sway bar loose. Then do the sway bar adjustments.
2012 ML350 3.0 Turbo Diesel
Old 04-13-2004, 05:42 PM
I think if you can't balance the your car with the front adjusters and need to start rotating the rear torsion bars somethings been set wrong all along. By the way, the adjustable rear springplates don't look like the aftermarket ones you see in the catalogues. Preloading the sway bars is not the way to go!
Old 04-13-2004, 07:03 PM
lateapex911's Avatar
Yes......a BIG "NO, NEVER" on the sway bar as adjusters.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 04-13-2004, 08:12 PM
Chuck Moreland's Avatar
You get points for thinking of creative solutions.
But no points for the answer. Not a good idea.
You are dialing in pre-load such that you will experience different roll stiffness left and right. Handling will be very uneven and oversteer/understeer tendency will be different in left and right turns.
Maybe if your running NASCAR this will work, but for the rest of us - no.
Just use the adjuster screws as mentioned above. It's easy if you have the scales.
Chuck Moreland - elephantracing.com - vonnen.com
Old 04-13-2004, 08:39 PM
I would like to take Howard's idea a little further:
Instead of all that troublesome, inconvenient, under-the-car, drop-link adjusting, why not just do corner weights with tire pressures? And for really large discrepencies, perhaps a little different tire size?
This could go hand-in-hand with the "easy to use" checking your ride height with the top if the radio antenna.
Let us know how it works . . .
Ed LoPresti
RacePro Engineering
New York
Old 04-13-2004, 09:03 PM
Adjusting tire pressures is too inconvenient. You have to keep topping them off as they lose pressure. Too much work.
Better yet Ed, how about strapping balast weight to each corner? You could put it in the trunk and engine compartment.
I've got an old barbell set gathering dust in the basement. Maybe I can put the weights to better use
Old 04-13-2004, 09:47 PM
Ok, ok, guys. I yield to your experience. I like your alternative balance and ride height suggestions. They inspire me to share with you my battery replacement project. I have duct taped 150 "D" cells to the bottom of the car in a parallel/series network to simultaneously improve my polar moment and center of gravity. Cool,eh? On an appropriate thread I'll detail my brake line weight reduction scheme.
Howard
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 04-14-2004, 05:09 AM
Ed, Chuck - you guys are on the right track but are not going far enough....
four on-board tire pressure adjusters from a H1 Hummer, four load cells, a bit of computer, and you could have real-time tire pressure based corner balancing
Sounds like a plan, I think.
Bob Donally
'84 Carrera
Bob D
Old 04-14-2004, 05:23 AM
dickster's Avatar
then why touch it? ultimately it comes down to how the car handles.
btw - bad idea
Rich
'86 coupe
"there you are"
Old 04-14-2004, 05:40 AM
