Flunked the emissions test
I flunked the NJ car inspection today due to excessive emissions. I intend to change the plugs, distributor cap, distributor rotor, air filter. What else should I consider to get my car to pass (I don't have the print out in front of me but, it wasn't that bad but, bad enough not to pass).
1987 Carrera, Guards Red, Black (sold but never forgotten!) 1965 356SC Coupe, Silver on Red |
Things to check:
1. O2 sensor working 2. air flow meter is stock (no adjustments made) 3. fuel pressure is O.K. 4. CAT has not been removed 5. No performance chip 6. temp sensor O.K. Check out this web site (www.systemsc.com) on the Problems page.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
What were the NOx and CO readings? A car 17 years old probably has a used up cat converter.
RETIRED
Do all your adjusting during or followed up with an exhaust gas anlayzer.....if all else fails...accidently pull an injector wire...instant air pump and diluted exhaust gas.....
edit for spelling....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 04-15-2004 at 06:39 AM.. |
Greg,
PM me if you flunk again. Good Luck
Warren & Ron, may you rest in Peace. |
