Trunk Light Switch Location?
Hi there,
My car was in the panel shop for some minor TLC and it turns out those crazy mixed up fools have not reinstalled the trunk light switch correctly. The light is permanently on which is not a good thing for the poor battery (had to push start it on Friday after work much to the amusement of the office chicks).
Naturally enough, I have pulled the globe but I would like to know where the switch is so I can fix it properly over the weekend.
Any clues? I'm stumped.
Audi B7 S4
Old 04-17-2004, 03:48 AM
3.2 CAB's Avatar
Look in the area of the right hand hood hinge(pass. side). I mounts in the hood and contacts the little plate just inside the lip of the trunk seal at the upper right corner. If your car is right hand drive this would be the drivers side.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 04-17-2004, 03:55 AM
Thanks 3.2 CAB. Now I know what the little black broken thing is dangling on the end of the earth wire.
Any idea how to reinstall the switch into the hood?
Audi B7 S4
Old 04-17-2004, 04:06 AM
3.2 CAB's Avatar
It should have a nut that threads over the housing that sticks thru the metal. There should be a hole it goes thru from the top side, then the nut goes on over what is sticking out and tightened in place. If the button part has come out of the plunger switch, you might need to get a new switch.
Newest additions-
others...
Old 04-18-2004, 05:22 AM
Thanks man, I'll check it out.
Audi B7 S4
Old 04-18-2004, 05:40 AM
