gerard vaglio's Avatar
Best of luck, keep us posted.
Old 05-24-2004, 11:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #281 (permalink)
Semper drive!
rcecale's Avatar
Jim, John....John, Jim....!!! YOU GUYS ROCK!!!!!
Well, obviously, I was able to repair the threads. YES!!!!!
Took my time and worked the rethreading tap up into the hole...slowly but surely...pulled it out completely several times, cleaned out the hole, blew it out with compresed air, oiled up the tap and back in she went, over and over until I got the threads cleaned up...all the way up to the end.
Finally, tried the bolt and in it went. Removed the bolt before tightening it down to install the support assembly. Held the assembly in the right spot and put in all the nuts and bolts, just finger tight, then slowly worked them in until they were all TIGHT!!!
Split washers in place on the tranny mount bolts gave me just enough room to tighten them to torque and there she sits. Just have to connect and reinstall the things I took off the engine to do the drop and she should be ready to go.
Thanks again, both of you, for all your help!
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 05-25-2004, 05:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #282 (permalink)
I've said it before, but what with the surreally beautiful photographs, the terse prose of John and Jim, and Randy's optimism and ability, this thread is one of the most exhilarating Porsche experiences I've had--away from the track.
Beethoven
'88 911 Coupe
Old 05-25-2004, 05:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #283 (permalink)
Semper drive!
rcecale's Avatar
Here she sits....tightened down and ready to roll.
Just wanted to doublecheck this installation. Got the big black cable coming from the battery and the red wire here in this pic connected to the same spot, and the yellow wire connected to the other clip on terminal...I believe this is right...hard to tell from the pic I took at the begining of this thread.
Randy
One Marine's View
Old 05-26-2004, 10:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #284 (permalink)
That's correct. Jim
Old 05-26-2004, 11:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #285 (permalink)
Semper drive!
rcecale's Avatar
Well, I am really close now. Spent the evening connecting everything back up. Double-checked, walked away for a while, came back and triple-checked. It looks as though I got everything.
Even went as far as walking through the steps spelled out in Wayne's Engine Removal Technical Article (The one I used to drop the engine) and checked things off as I read them...knowing that each piece, hose, clamp, or plug has been re-connected.
Right now, I just put a bunch of oil in the engine. She took 9 quarts and the indicator shows about 1/2 inch short of the second mark.
Is 9 quarts enough? I seem to recall reading that it should hold more than that. While pulling it out, I removed or disconnected ALL of the oil lines in the rear end...and that's it. Between the engine oil and the transmission fluid, I managed to fit it all into a 3.5 gallon bucket. Seems to add up right...1 gal of tranny fluid and 2.25 gals of oil.
Is 9 quarts right at this point?
Randy
P.S. If all goes well, I just need to connect the battery, slap the rear tires back on, lower her off the jackstands and fire her up. WOW!!!!! I could be driving her this weekend! Think I'm getting excited?????
One Marine's View
Old 05-26-2004, 09:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #286 (permalink)
I assume you changed out the oil filter so it's probably empty and will fill as soon as the oil pump runs. Nine will likely be okay but I'd go ahead and add a 10th quart, then top off later as required when the engine is warm. Have someone watching the engine for leaks (gasoline and oil) when you start and have a fire extinguisher out and ready. Make sure your oil pressure is correct (rag left in oil line?). Don't forget things like torquing the rear wheel lug nuts, CV joints, adjusting shift coupler and clutch, removing the front wheel chocks and clearing all tools, debris, rags and old parts from the engine bay. Cheers, Jim
Old 05-26-2004, 09:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #287 (permalink)
Semper drive!
rcecale's Avatar
Yes, Jim, the oil filter was changed and upon your advice, the 10th quart has been added. I thought that might be the case.
Using your post as a reference, the following have been accomplished:
Fire Extinguisher - In the garage
Oil Lines - Cleared
CV Joints - Torqued
Lug Nuts - Will be torqued upon installation
Shift Coupler - Adjusted according to an article posted here on Pelican
Clutch - Will test during first drive
All Tools, Rags, Debris, Etc... - Cleared and accounted for.
While in the Marines, we made it a requirement to do an ATAF (All Tools Accounted For) at the end of each job, end of each shift, etc. This habit served us well then and continues to serve me well even now. Keeping it clean and knowing where everything is...when you need it, saves so much down time and also lets you keep your mind on the task at hand....helps you to not forget things by being distracted.
Well, calling it quits for the night. Hopefully, I'll be posting back here again tomorrw night with a pic of me motoring down the street. Kinda feel like a kid on Christmas Eve...
Randy
One Marine's View
Old 05-26-2004, 09:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #288 (permalink)
Semper drive!
rcecale's Avatar
She is all back together and working like a champ!
THANK YOU SO VERY MUCH TO EVERYONE WHO HELPED ME TO ACCOMPLISH THIS JOB!
John Walker, Jim Sims, UTKarmann_Ghia (Matt, you Devil Dog!), Ischmitz, Grady Clay, and everyone else who joined in to make this one heckuva learning experience for me. Also, can't forget Jay Houghton, Josh Roberts and Dan Wooley, another neighborhood Pelican who were also very instrumental in the success of this evolution. I couldn't have done this without each and every one of you. I am definitely in your debt!
After spending the evening last night connecting everything up, I was left with just installing the tires, connecting the battery and the speedo cable today.
Well, the battery and tires went without issue, and I still haven't spliced the speedo wires together yet. I'll get to that this weekend.
Once everything was set, I hopped in and turned the key...my wife standing faithfully nearby, fire extinguisher in hand, and...all I could hear was the fuel pump...she wouldn't turn over....hmmmmm?
Back up in the air, I gave a call to Dan Wooley and when he showed up, we took a look. There were a few spades on the starter where we could hook the smallest of the three wires. One was like a dual spade, the other was a single. Moved the wire from the dual to the signal and tried it again....and she sprang to life..as if she had been waiting patiently for this opportunity.
Took another look at everything while she ran for a while and it all looked good...sounded good...so around the neighborhood we went.....and she shifted like a dream. Nice and tight, no binding or anything...just in and out of gear, whichever gear was selected....it was so awesome! I have my car back!!!!!!
I can't say "Thank You!" enough, but "THANK YOU! "
Oh yeah, don't want to forget Wayne, who, if it wasn't for his website, I would be so stuck! Thanks, Wayne!
If any of you guys are in the area, please stop by, or give a yell, or whatever....at least let me shake your hand!!!
Randy
One Marine's View
Old 05-27-2004, 08:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #289 (permalink)
Go Speedracer, go!
SpeedracerIndy's Avatar
CONGRATS!!! I feel like I just sat through a graduation ceremony. Glad to hear it all went together well and I hope to be joining your ranks within the next week.
1981 SC ROW Coupe
Old 05-27-2004, 08:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #290 (permalink)
Pics! Pics!
Beethoven
'88 911 Coupe
Old 05-27-2004, 08:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #291 (permalink)
Semper drive!
rcecale's Avatar
Hey, CD, I feel like I just graduated! What a school!!!! I have faith in you, man. If I can do this, you'll have no problems, none whatsoever. Just take your time and be very meticulous while putting it back together...I've been wearing this silly grin since I fired her up...think I'll be sporting it for quite a while.
Beethoven, I'll be getting some pics this weekend, when its light outside. I'll have my wife snap one of me rolling down the street, and I'll try not to glare the photo too much with this huge smile I'm wearing!
You know, I've been meaning to mention this for a while, so I'll do it now. When this thread first started, John Walker was the first to reply. And with only the little bit of information I was able to provide at the time, he immediately made the exact diagnosis as to what my problem was. (Man, that sounds so cool...WAS! )
Anyway, what a true master of his craft. I can't say enough about what a great guy John is. For that matter, so is everyone else who contributed.
Thanks again!
Randy
One Marine's View
Old 05-27-2004, 08:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #292 (permalink)
Yeah, John rocks. Only reason I consider moving to Seattle...
Beethoven
'88 911 Coupe
Old 05-27-2004, 08:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #293 (permalink)
It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Congrats! I am printing this thread for when I do this later this summer. Keep your computer on ;-}
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 05-28-2004, 04:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #294 (permalink)
Semper drive!
rcecale's Avatar
SHHHHHHHHH!!!!! She's sleeping! Taking a rest after having major surgery performed on her.
It is so nice to not have her sitting on jack stands again!
Randy
edit: Speed Buggy, I thought I would add this list of valuable resources that you'll probably want to use when you do your tranny this summer...
http://www.pelicanparts.com/techarticles/911_engine_drop/911_engine_drop-1.htm
http://www.pelicanparts.com/motorcity/marcesq3/trannyrebuild.htm
http://www.fasterfasterfaster.com/Tranny.html
john walker's workshop
UTKarmann_Ghia
ischmitz
Jim Sims
Grady Clay
One Marine's View
Old 05-28-2004, 04:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #295 (permalink)
It's a trap...
Thank you. I have found some parts lists in your and other threads, but I am having a hard time duplicating some of the parts on Pelican, such as brake bands. Are these called something else here? Congrats again. You and CD and the others have convinced me and the wife and kids to do this ourselves.
Old 05-28-2004, 05:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #296 (permalink)
Semper drive!
rcecale's Avatar
Yeah, I had some difficulties from time to time, keeping the nomenclature straight. It can get confusing.
If I have it right, the Brake Band can also be called the Energizer Band.
Do you have a FAX number? You can PM it to me and I can send you copies of what Grady Clay sent me. They may be a bit difficult to read since it will be a FAX copy of a FAX, but I'm sure it will help. Lemme know!
Randy
One Marine's View
Old 05-28-2004, 05:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #297 (permalink)
ischmitz's Avatar
Send a message via Skype™ to ischmitz
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-28-2004, 10:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #298 (permalink)
Semper drive!
rcecale's Avatar
Ingo!!!!
I couldn't have said it better myself! Thanks Loads, buddy!!!!!
Randy
One Marine's View
Old 05-28-2004, 10:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #299 (permalink)
It's a trap...
Randy - you have a PM
Cheers, Mike
Old 05-28-2004, 10:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #300 (permalink)
