LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
Originally Posted by Flojo View Post
Hello, what 28mm Discs to get?
I can only source the 24s for a plug and play mount to the SC hub (Sebro 275197 or Zimmermann 45662Z).
And what hard line do I get to adapt the 964 caliper?
re-bend the SC line? get the 964 line and re-bend?
My archived notes (thread by Bill Verburg, 2002) say the front rotors from a 1986 944 Turbo can be used (298 x 28mm), same as used on the brake kit sold by VCI;
944 turbo brake upgrade
In another thread (2009),
Kevin L (KTL) adds that the 944 Turbo rotor must be spaced outward on the spindle approx. 5mm (~0.20”) to center the rotor within the caliper…….
…. and that a C2 front rotor (same size, different offset) will work with the rotor slipped over the front hub (hub OD machined to fit), a setup created by Steve Timmons (Instant-G).
https://forums.pelicanparts.com/porsche-911-technical-forum/493457-c2-front-caliper-sc-carrera.html
Sherwood
Old 12-02-2019, 02:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
Bill Verburg's Avatar
Sherwood
I have never said that 944 rotors can be used on a 911
Bill Verburg
Old 12-02-2019, 02:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
Bill, I stand corrected.
944 Turbo rotors are 299x28mm, used by VCI in their upgrade kit (front) and used by others.
You suggested the larger 930, 309x28mm rotor (rear) to avoid pad overhang. That right?
S
Old 12-02-2019, 03:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
S
When I used 964 calipers on my car I used 930 f/r rotors, 304x32 front and 309x28 rear, It was so long ago I forget the reasoning, but I seem to recall that they were the best fit that was available for a 911 w/ 964 calipers, Today I would probably use the same rotors w/ 993 calipers. Currently on my hot rod I have 993RS calipers and rotors, Same as on my track car
Bill Verburg
Old 12-02-2019, 04:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
911tracker85's Avatar
my 78 SC/930 conversion still had the original SC brakes and suspension.
got a set of 930 calipers, just got the rears back from being modified to fit.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 12-03-2019, 05:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
Sherwood
The hubs Instant-G supplies for the 993/993TT/996/996TT kits - which use the appropriate factory rotors for each caliper BTW - do not use 911 hubs AFAIK. It's been years, but seem to recall him saying there was not enough there to safely machine them down when I bought my 996 conversion.
Someone else said they were machined-down 951 hubs, but i dunno...
If you go with an Instant-G kit, for best results budget in a dual-master pedal box/Fabspeed conversion as well. Otherwise the front bias inherent in all of those setups leaves a lot of potential on the table.
But the rotors/pads don't wear, and brake bleeding becomes a 2-3 year maintenance item because brake fluid is hygroscopic...
'77 S with '78 930 power and a few other things.
Old 12-03-2019, 10:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
when I did the boxster caliper upgrade to my 85, I replaced the factory rear bias valve with a tilton adjustable. completely opened up the rear bias and the rears never locked up prematurely.
now when I tried this on my 86 951 build I did not open the rear bias much before they were locking up.
I plan to install an adjustable bias valve on the rear line. expect that will give me enough adjustablilty to max the braking.
Bob Cox
Old 12-04-2019, 05:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
Boxster/Boxster on 3.2C rotors has a native brake torque bias of 1.669
Boxster/WideM on 3.2C rotors has better bias @ 1.554
911 goal for bias is ~1.5('72- '83 is 1.491) or even a little less if the car is setup for it, Both of mine have 1.426
A p/v can only move bias forward, having too much front isn't dangerous it just leaves brakeing potential on the table. W/ either of the above Boxster changes(I refuse to call them upgrades) you wouldn't want any p/v
Bill Verburg
Old 12-04-2019, 09:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
dont understand....
there is no bias valve on the front brake line, but there is on the rear.
so if you remove the bias valve from the rear line and replace with adjustable, you can increase the amount of brake pressure to the rears. dont see how that affects the front pressure? that is how I see the system and how it worked for me. and when trying this on my 951, the rear calipers are big enough they start locking up as I opened the bias valve on that line.
Bob Cox
Old 12-05-2019, 10:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
dont understand....
correct, a 3.2 C has a 33bar p/v on the rear circuit
no, a p/v can only reduce line pressure on the circuit, an adjustable one just allows you to vary the amount of reduction. It is true that an adjustable might increase the line pressure above what the stock 33bar one would allow, But it will never allow more than an open line. bias is derived from integrating the effect of the brake torque in front w/ the brake torque in back.
target bias fora 911 is ~1.5
a stock 3.2 is 1.220 below the 33bar knee and 2.260 above it, below the knee is too much rear which is fine as long as the rear tires have enough grip and above the knee is too much front, this is the safer regime and also fine until the front tires grip is surpassed. An adjustable p/v justs changes where the knee is
Bill Verburg
Old 12-05-2019, 11:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
I'm in the process of installing 993 calipers on my 73 911. I notice a few installs use square aluminum stock as a front adapter. What size stock do I need and is it standard 5051 aluminum?
Old 12-05-2019, 09:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
Jeff Alton's Avatar
Measure and machine as appropriate. 6061 T6 would be a good choice.
www.turn3autosport.com
Old 12-05-2019, 10:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
Flojo's Avatar
Bill, please, what connecting hose do you use between the caliper and the hardline?
Thanks,
Flo
993RS/993tt
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 12-11-2019, 05:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
Thanks,
Flo
The pic is of my C3 w/ 993RS brakes
here's the line
With the 964 on 930 that I used to use
Bill Verburg
Old 12-11-2019, 09:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
Flojo's Avatar
thank you, that's the one.
I was looking for such a line... jus ordered a set of custom made ones.
T
here's the line
Old 12-11-2019, 11:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
Another question as I progress with my 993 brake install. Does one modify the brake rotor backing plate or get rid of it?
Old 12-22-2019, 09:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
Flojo's Avatar
racers would leave them off, better air-to-disc access and some weight saving.
you can do this though:
Old 12-23-2019, 01:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
Thanks. That is kind of what I was thinking since alot of the pictures of upgraded brakes don't show the plate.
Old 12-27-2019, 11:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
Flojo's Avatar
Anybody modified SC front hubs to carry 930 discs?
What to do? I recall from somewhere that the diameter must be reduced? Is that all? What are the specs?
Thanks!
Old 12-28-2019, 06:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
I am on the same quest.
Bob Cox
Old 12-29-2019, 05:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
