Broke
Geeeeez, another PPI ?
My PPi just indicated 150 in all cylinders. Now I'm hearing you guys talking about 170 and 175. 20-25 diff? Whasup with that????
Beer is proof that God loves us and wants us to be happy. B. Franklin 93 968 Cab 81 SC Targa (Princess) Now Residing in Denmark 1973 RS Z28 Vash will never own it! |
from what i learned it isnt the numbers, but the consistency.
poof! gone |
Broke
Yah, but I'm not constipated! Oh,,,um,,, never mind
also depends on the year and engine model. And how well the test was done.
Broke
81 SC. Should be the same as 80 thru 83,,,right???
I would be happy with 150 all across.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Now in 993 land ...
Absolute numbers are practically meaningless. Here is only a few factors that can change the absolute number tremendously:
air pressure temperatures (outside and engine) battery power starter what's with the other spark plugs? throttle open or closed during test? the compression tester used (none of them are absolutely calibrated). So, you see, any of the above factors can get you lower or higher than numbers you read on the board. To clarify: It is important that your numbers are within 10% of each other. Take your highest number and subtract 10%. If all other numbers are within that range, you are okay. George |
