jbripps's Avatar
Getting Fuchs 16 x 9's.....what tire sizes should I get?
Hi all,
I've decided to keep my car rather than getting something newer. Anyhow, with my decision comes a gift to myself. I will be getting 16x9's for the rear, and I'm not too sure what size tires to get. I've seen a lot of archived threads with many different sizes.
I want to put tires on that will look the best (sidewalls) without being too big or small. Of course, I'll need optimal performance. I don't really need too much advice on what brand and type to get, just the sizes. Any advise will be appreciated.
Also, on a side note, I plan on keeping the same size tires on my 7's for the front (my original rears). I'm pretty sure they are 205/55? Possibly 50's......will those be OK up front? Or should I get a different width?
regards,
Jon
Jon
'85 Targa (recently acquired by Coollx)
'02 Carrera 4S (holy moly...I'm in heaven....in the snow too)
'06 BMW 325i (gone and forgotten)
'03 Honda Odyssey (more dings every day....thanks wifey)
Old 04-29-2004, 06:11 PM
245-45-16 rear / 205-55-16 front
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 04-29-2004, 06:23 PM
palle7688's Avatar
I agree with mike
You might not be happier owning a Porsche, but it certainly feels so driving one
Old 04-30-2004, 08:48 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Re: Getting Fuchs 16 x 9's.....what tire sizes should I get?
Originally posted by jbripps
.................... Also, on a side note, I plan on keeping the same size tires on my 7's for the front (my original rears). I'm pretty sure they are 205/55? Possibly 50's......will those be OK up front? Or should I get a different width?
regards,
Jon
Are you saying that you plan to use the current rear tires (and 16x7 wheels) up front? That may not work. The std. rear tire size is 225/50. Sometimes the 225/50 on a 16x7 up front has clearance problems. Rolled fender lips and/or more neg. camber for the alignment setting is the usual solution. But, sometimes people have no problems at all. Depends on your tire dimensions too.
Kevin L
'86 Carrera "Larry"
Old 04-30-2004, 09:51 AM
Glasgow 911SC's Avatar
There's some good tyre info in this thread.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 04-30-2004, 11:38 AM
I have 16x8's on the front with 205 and 16x9 on the rear with 245/50's. Like mentioned above there was a clearance issue with 225 on the front.
78 SC
Kurt
Old 04-30-2004, 11:42 AM
Correction on my last post my rear tire size is 245/45/16.
________
78 SC
Kurt
Old 04-30-2004, 11:44 AM
Mark Wilson
Guest
Posts: n/a
245/45 and 205/50 on 7's and 9's. No rubadub
Old 04-30-2004, 01:19 PM
Bye, Bye.
Scooter's Avatar
Ditto!
Elvis has left the building.
Old 04-30-2004, 02:32 PM
jbripps's Avatar
Hi all,
Thanks so much for the responses. Yes, I will be using the current 7's on the rear and moving them to the front. I guess I may have to get smaller tires put on the rims, as they are 225's now. I didn't realize that the 7's could have 205's on them.
That's OK b/c they are pretty worn. Thanks again!
regards,
Jon
Old 05-01-2004, 05:50 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Definitely 205/55/16 & 245/45/16.
Best combo IMHO.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 05-01-2004, 07:47 PM
jbripps's Avatar
Zoanas,
Great looking car and great wheel setup too. Thanks for the input.
regards,
Jon
Old 05-02-2004, 01:13 PM
UFLYICU
ZOA NOM's Avatar
Thanks Jon. I was all set to send the wheels to Harvey Weidman for polished paddles, but I polished my black center caps just to play around with my dremel tool, and I kinda like the look. From a distance it looks like a racing wheel with a single large lug nut holding it on.
prc-racing.com
Old 05-02-2004, 08:12 PM
Sonic dB's Avatar
Just something to be weary of...
I put 45s on my 9s in the back, going from the PO's 50s which he stuck on there...
Now, the gap between the wheel well and the tire is too significant and i have to lower it an inch or two to make it look cool.
Old 05-02-2004, 08:17 PM
