Question Is Fabspeed built by Flowmaster?
I thought I had read somewhere that the 1 in 2 out Fabspeed muffler for a 911 (3.0/3.2) was made by Flowmaster. If this is true is the only difference the stainless construction, all the interior designs are the same? I loved the sound of my gutted cat with 1 in 2 out Flowmaster but the drone at cruising speed was a little annoying. I was considering the Fabspeed but if I am to expect the same resonance I might as well spend $$hundreds less for the Flowmaster. Other than the resonance the Flowmaster has an intoxicating growl!
The new muffler is for my new(to me) 87 Carrera to be picked up this weekend!!
Scott
1987 911 Targa
Old 05-03-2004, 03:16 PM
v9ff's Avatar
I belive you are correct but it's probably more appropriate to say that Fabspeed uses Flowmaster mufflers in their construction.
Old 05-03-2004, 03:27 PM
Location: member Central PA Region PCA , Home of the Hershey Swap
I do not believe so, but you can email Joe Fabiani via there www.fabspeed.com website and ask. They use the "maxflow"
name and it's my understanding that they do all of their own manufacturing here in Central PA.
regards,
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Old 05-03-2004, 03:32 PM
I had one on my 3.2 and the drone was unbearable.
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 05-03-2004, 06:30 PM
Navin Johnson
TimT's Avatar
Yikes the secret is out!
'69 911 GT-5
'75 914 GT-3
and others
Old 05-03-2004, 06:37 PM
SRISER's Avatar
I have the FS 1/2 and it doesn't bother me at all...at any speed. I even like it when the car alarms around me go off...
Sam
'02 996 TT
'07 Audi S4 Avant
'88 Carrera (Sold)
Old 05-03-2004, 06:39 PM
had that happen tonight, just waited till it shut off and revved it again. I enjoy Fabspeed 2/1.
Mike B.
Gilbert, Az
89 911 Coupe
Old 05-03-2004, 09:29 PM
I had a Flowmaster 1/2 on my 3.2 with an intact cat and there was no drone at any point.
Old 05-03-2004, 09:48 PM
Administrator
Jack Olsen's Avatar
I think it's only the 2-outlet models that drone.
I just installed a 2/2, and it has some drone from 2000-2800 rpm. It's almost entirely reduced if I cap one side. I suspect that changing the pipes before the inlet or after the outlet might change the 'drone zone.'
It's much less annoying than the resonating drone from my old B&B, tough.
Old 05-03-2004, 09:59 PM
I have a 1 in 2 out on my 85 Carrera. It is LOUD but there's no drone at all.
Old 05-04-2004, 05:46 AM
Administrator
Jack Olsen's Avatar
My post is worded wrong. I meant that maybe it's only the 2-inlet models that drone.
Old 05-04-2004, 10:36 AM
Jack,
Which particular or model # Flowmaster are you using?
I currently have a 1/1 Bursch using the Dynomax Turbo #17733 muffler, I am going to build a new muffler system myself, set on 2/2 muffler, just undecided on which brand muffler.
I want a muffler that would be louder than my current, any suggestions?
Miles
'80 911sc Coupe
Oahu, Hawaii
USA
Old 05-04-2004, 05:14 PM
Administrator
Jack Olsen's Avatar
Flowmaster is rhaspy, gutteral, and pretty loud. I've got a 2/2 80-series, I think.
Old 05-04-2004, 05:45 PM
My B&B, dual in and out w/same B&B headers Drones (resonates) awful at 2400-2800 RPM .
regards,
Old 05-04-2004, 06:45 PM
