Send a message via Yahoo to 911Brian
Question Single most effective upgrade to susp
What is the single most effective upgrade to a 24 year old suspension?
86 Carrera Red/Black
80 SC Coupe Silver/Black (gone but not forgotten)
Old 05-04-2004, 05:44 AM
Senior Member
Bilstein (or Koni) shocks.
JoeA
Old 05-04-2004, 05:49 AM
DJB DJB is offline
DJB's Avatar
Yup a set of Konis on the Cab - unbelievable difference. 18's also made a huge difference in many ways - but IMHO the Konis win.
Cayenne Turbo - Cargraphic Stage 2 Power kit, lowering module
997 C4 Cabriolet - Basalt Black
86 Turbo Body 911 Cab - Many Mods
Gone and Missed:
97 993TT: PSS9, CarGraphic Exhaust
Old 05-04-2004, 05:54 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
Tyson
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 05-04-2004, 06:02 AM
Bilsteins
Sean
'77 911S Cab Conversion
Old 05-04-2004, 06:13 AM
all good advice.... what are your driving habits ? Koni's are the best for
some... Bilsteins are good for others. either way lowering the car made the biggest improvement for me.
Old 05-04-2004, 06:50 AM
chrisp's Avatar
If your shocks are bad then start there.
If your shocks are good then I suggest (in order)
lowering to Euro spec (don't go much lower with OEM torsion bars)
sway bars
torsion bars
bushings
Lowering is free except for the alignment.
Overall except for shocks and sway bars the rest will require a realignment once it's done. So, I would group lowering, torsion bars and bushings together.
'83 SC
Old 05-04-2004, 06:56 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
bushings ?
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-04-2004, 06:59 AM
http://www.unlimitedlaps.com/
http://www.tracquest.com/
http://www.ncracing.org/
http://www.trackmasters-racing.com/
Old 05-04-2004, 07:03 AM
I'm surprised Thom was the first to suggest seat time. It was the first thing i thought of when i saw the thread title, but first make sure the suspension/car is in good repair.
Hmm, I would suggest this in this order
Great tires (they are the most important part of the car, if they suck it doesn't matter what the rest of the suspension is doing)
bushings
Shocks (I second or third the Bilstein vote)
Lower, Corner balance, and alignment
Lots of seat time (learn to drive the thing)
and these last two are hotly debated, so they are in no particular order
Sway bars
Torsion Bars
Old 05-04-2004, 07:08 AM
Information Junky
island911's Avatar
Education. If you don't understand how suspension components interact, then you likely go into a very expensive trial & error mode. (good for those selling suspention comp's though)
Also, there are track people who will push the "stiffer is better" . . if that is your ultimate goal, save yourself some headache and buy a go-kart, and kick some tracked-911 butt . . .just don't drive it on the street (it will rattle your brain loose)
IMO, those Porsche engineers got the balance of the components right . . .for a street car. So, like masraum said; make sure the suspension/car is in good repair.
If, however, your 911 has the stock US ride height, then lowering will be by far the single most effective suspension upgrade. (The suspension design intent was sacrificed to the bumper gods, circa 1980) Of course, with lowering, your bumper-height may nolonger adhere to the laws of 1980. (oh darn)
Old 05-04-2004, 09:17 AM
Thanks for the replies! I know I need much improvement myself. I autocross as often as I can. As far as I know, the entire suspension is 24 years old and stock and most likely a little worn out. Just looking for the most bang for my buck right now to get it at least to where it was 24 years ago and then some.
Sounds like seat time and new shocks are the way to go for now.
Old 05-04-2004, 10:27 AM
Randy Webb's Avatar
Define "most effective" - do you include cost? If not, shocks. Tires aren't really part of the suspension; otherwise them too.
If cost is included (and you provide the labor), then you need to replace every single piece of rubber in that worn, stiff 24 year old suspension -- and that includes the top F shock mounts. For the street, use stock rubber, or Elephant's bearings. Search the forum.
Old 05-04-2004, 10:57 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Also, shocks are pretty easy to replace relative to other cars.
On the SC, the top nut on the rear shocks are kinda hard to get at because of the CIS and airbox assembly. Other than that they are straightforward.
Fronts are a bit stubborn but easily doable with a couple big pipe wrenches and two people.
The bang for the buck is good when it comes to shocks. Noticeable improvement instantly. And probably desperately needed after 24 years. The two front shock jobs i've done (86 & 87 Carreras) had worn out shocks that were amazingly soft. The amount of damping left in them was very minimal.
One other thing that wasn't mentioned is tie rods. The Turbo tie rod upgrade/replacement is a good improvement. Makes the steering nice and tight again. Also a good thing because you are forced to feel the improvement every time you drive the car.
Kevin L
'86 Carrera "Larry"
Old 05-04-2004, 11:04 AM
zotman72's Avatar
Counter to the rest of you, I would say torsion bars. Changing up from stock sizes made all the difference for me on my '72. I already upgraded my dampers (shocks) to Bilsteins but the effect of stiffer spring rates reduced my body roll, along with same time lowering. My sways are stock but I do have a good front strut brace. HTH.
Bill
'72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride.
Old 05-04-2004, 11:13 AM
I will provide the labor. I would love to do it all but don't think I can afford that right now. I would love to get some of Elephant's bearings but right now, looking for something that would provide me with less body roll. Not really looking for a "stiffer" ride but a little better cornering in mainly autocross. I am still learning how to control the car but am itching to start upgrading slowly.
Old 05-04-2004, 11:42 AM
Eric Coffey's Avatar
Lower CG and less overall weight.
Old 05-04-2004, 12:03 PM
