1973911s's Avatar
Lowering front end, can this be a DIY
Is there a technical article on Pelican on how to lower the front end, or where to find the 10mm bolt?
I have heard this is really easy, would like to come down about half an inch?
Michael
1984 Carrera Targa Sold to fellow Pelican
1973 911S Targa - Sold to fellow Pelican.
Old 05-09-2004, 09:11 AM
It's really easy. The lowering bolt sticks out from the back of the A-arm facing down (may be at a slight angle) from the end of the torsion bar cap. You can probably see it between the spokes on the Fuchs. Get under there with a socket wrench (11 or 12 mm socket...can't remember right now) and loosen the bolt one complete turn on each side (As I recall, one turn is good for a 1/4" drop). Try to do this evenly from side-to-side. After you've done one turn on each side, bounce the car to get it to settle. I find the best way to do this is to stand on the door sill and bounce. One thing to keep in mind is that this will throw off your corner-balance.
Old 05-09-2004, 09:53 AM
Grady Clay's Avatar
BTW, your toe and camber will also change.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 05-09-2004, 10:15 AM
You can lower it yourself in about 30 seconds per side. If you go down a 1/2" definitely realign.
Old 05-09-2004, 11:31 AM
Reg Reg is online now
Reg's Avatar
My car sits a little high in the rear. Would this be less noticable if I tightened the two bolts one turn on each side? I suppose that too will mess with the toe and camber on the car. If I reverted back the turn afterwards would everything be back as it were?
1970 911 t (sold)
1985 MR2 (sold)
2011 GT 5.0
2007 CRV
Old 05-09-2004, 12:10 PM
efhughes3's Avatar
You might also be careful of fender clearance, see my post of a few minutes ago:
$1000 later, I've got rolled fender lips!
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 05-09-2004, 12:12 PM
