Unhappy Screwed Up Clutch by Replacing Shift Rod Coupler???
I replaced the ball cup, shift rod coupler and shift rod bushings on my 915. I adjusted the shift rod coupler according to Wayne’s 100 projects book and the tranny shifts into all gears and feels GREAT!
The only problem is the clutch slips in 1st gear. It engages fine in reverse but slips and the car stalls in 1st! The clutch worked great before I tinkered with the car, (clutch replaced at 77K car now has 85K).
Could I have screwed up the clutch by replacing the bushings??? Wayne dosen't say anything about the clutch in project 37 (Shifting Improvements).
Please Help,
Alan Stark
1988 924 S
500 in US
Black (the only color)
82 SC Guards Red/Black . (Sold)
SSI's, No Cat, Bursch, H4's plus relays/wiring upgrade
Old 05-10-2004, 02:20 PM
Todd Simpson's Avatar
None of the stuff you've done affects the clutch.
What exactly is happening? A slipping clutch doesn't cause the engine to stall...clutches usually slip in 3rd or higher when you try to accelerate.
Old 05-10-2004, 02:49 PM
Todd
That's what I was thinking, but I am new at p-cars and their repair.
I replaced the bushings per Wayne's book. Reinstalled the coupler bushing and aligned it according to Wayne's instructions.
When I shift into first and start to accelerate, the car stalls. Clutch feels like it is slipping (if I give it gas I can get it to go, but it is definately different). I had no problems prior to bushing replacement.
I am stumped!
Help
Alan
1988 924 S
500 in US
Old 05-10-2004, 05:56 PM
AFJuvat's Avatar
Reinstall the shift coupler - You aren't lined up properly.
Remove and reinstall,.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-10-2004, 08:11 PM
The orientation of the shift rod coupler will definitely give you problems if installed the wrong way. I think there is a pretty good thread in this forum describing the proper way to install it.
Old 05-10-2004, 11:09 PM
Thanks Ed and AFJuvat--
I will readjust coupler, although I have done it numerous times and research the thread on the board.
Alan
1988 924 S
500 in US
Old 05-11-2004, 06:12 AM
Broke
Westy's Avatar
PS. You'll always know if the clutch is screwed up. Remember that sweet disgusting smell from you 65 chevy right before it had to be parked on the side of the highway. Ahhhhh, a fragrance we'll never forget, and one that's the same in all manual trannys.
B
Beer is proof that God loves us and wants us to be happy. B. Franklin
93 968 Cab
81 SC Targa (Princess) Now Residing in Denmark
1973 RS Z28 Vash will never own it!
Old 05-11-2004, 06:29 AM
I remember Westy--but my car was an Austin Healy 3000 and it was 1969. Could hardly smell the clutch over the exhaust smell!
Alan
1988 924 S
500 in US
Old 05-11-2004, 06:38 AM
Limbo
Slider79SC's Avatar
Alan,
My bet is that your coupler is out of adjustment. It appears that you are more than likely in third and not first, that is why it is stalling and requires more effort to get moving.
JM
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 05-11-2004, 06:49 AM
3.2 CAB's Avatar
Ditto with Slider.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 05-11-2004, 07:15 AM
BOING!!
Slider/3/2 that makes sense!!! Will check when finished with work today.
Thanks,
Alan
1988 924 S
500 in US
Old 05-11-2004, 07:47 AM
