better backwards
Somebody who appears to be intelligent suggested that an early 911 would have better aerodynamics if it were to travel in reverse.
I've spent all day looking at mine and it does seem like quite a reasonable suggestion. Any ideas?
Steve in South Africa If it isn't sideways, it isn't fun |
Somewhere in the Midwest
The 911 would be more "streamlined" traveling backward, what fun woudl it be if the engine were in front and you were facing backwards
Probably true, but aerodynamics mean little downforce is what really matters. Better downforce facing forwards I believe.
68 911L |
Non Compos Mentis
I've heard that the early 928s had a lower Cd going backwards.
I've never heard that about a 911. Maybe..... |
Think water. Ive heard that the shape of a droplet of water is the most aerodynamic of any shape on the planet.
![]() 911s, and especially 928s, are more like a water droplet when in reverse than forwards.
'75 911S 3.0L '75 914 3.2 Honda J '67 912R-STi '05 Cayenne Turbo '99 LR Disco 2, gone but not forgotten |
Bird. It's the word...
At the risk of being a know-it-all
A droplet of water (or any other "drop" of viscous substance) will form a sphere within Earth's atmosphere. The shape above is indicative of the droplet as it leaves its source, surface tension will pull it into a round ball very rapidly.....
John Forcier Current: 68L 2.0 Hotrod - build underway |
Administrator
The difference between "most aerodynamic" and "best aerodynamics for driving corners fast" are two different things. You need to generate downforce to go fast around corners, and the unmodified early 911 shape is pretty terrible for that.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
What?
Drive it backwards? Then the motor would be in the front just like every other car! Next someone will suggest water cooling!
Tom J. 911SC Cab SCWDP CaymanS |
No, water drops from a shape like above as they fall due to aerodynamic forces. The Cd for a water drop shape is about 0.1
A complicating effect is that water is a liquid - not rigid. There was a guy named Lange or Lang who was doing hydrodynamics on dolphins, specifically the ability of the blubber to conform to the water interface -- funded on USN contracts. He found in one publ. that this surpressed the induction of turbulence. Then, I never saw or heard from hiim again. A few years later, the super secret new USN subs began appearing with a special special coating on the hulls. Draw your own conclusions.... |
lt was common knowledge that the original VW bug had a more efficient profile in the windtunnel-backwards.That`s probably where that came from.l pride myself on my ability to drive in reverse at high speeds(plenty of practice) but l`ll suck up the .02 and get it going forward
my life begins at 150MPH |
It is a well documented fact that the 928 is more aero efficient if it were to run backwards....I think the basis was total drag and lift.
---Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
1968 911L 2004 Dodge Dakota SLT Plus |
Interesting Randy.... The Blub-Sub
![]() I was thinking more about shot than water I suppose. We have a an old "shot tower" where I grew up. I was fascinated with the falling lead becoming round before being packed into cartridges etc...
I think it must be th reater denisty of Pb -- or maybe the very high surface tension of water is involved.
Do you guys still allow Pb shot over there? I know they are trying to restric it here - not to mention the suits by landowners next to shooting ranges. |
Author of "101 Projects"
The Aztec was designed around the theoretical perfect airfoil shape with the lowest possible coefficient of drag:
![]() I'm in this fuzzy pic somewhere... Hmm, pretty sure I'm the tall one with the jeans/jacket... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Is that a mullet you have Wayne?
Randy, same boat over here... still legal for the time being, but on the way out.
