Flywheel Bolts, Replace or Not
Well I put the old flywheel bolts back on the flywheel although the engine is still out of the car. I understand that these bolts are expansion bolts. I torqued them down to the proper 115ft-lbs. Do these bolts really need to be replaced?
zac
'71 911 s Targa
Old 05-21-2004, 10:20 AM
MT912RS's Avatar
Yep, those are stress to yield: i.e. good for one torquing.
Old 05-21-2004, 10:27 AM
Senior Member
Superman's Avatar
Pressure plate bolts are commonly reused, although most folks are scared to reuse them. While PP bolts can (according to some folks) be reused, not so with flywheel bolts. Always use brand new ones.
Mocha 1978 911SC. "Coco"
Old 05-21-2004, 10:29 AM
Randy Webb's Avatar
For the price, its good to use new PP bolts.
Also, you can put a _small_ dab of red Loctite on the flywheel bolts.
Be sure to torque properly and be sure the torque wrench is accurate.
for both sets, tighten a little bit at a time.
Old 05-21-2004, 10:49 AM
I am guilty of reusing my flywheels bolts many times, with red loctite, for many years with no issues.
I do not race, but drive very hard.
Your car, your money, your call !
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-21-2004, 11:05 AM
Okay, good one other person. I didn't want to have to get back into the clutch as my engine is almost back together.
Thanks for the help
'71 911 s Targa
Old 05-21-2004, 11:08 AM
kqw kqw is offline
Replace them.....
The Fox
Carrera
Old 05-21-2004, 11:19 AM
maxnine11's Avatar
a TSB from 25 years ago says its OK to reuse:
EDIT: note- this TSB refers to 1978 and later !!!!
max
Old 05-21-2004, 11:23 AM
kqw kqw is offline
Does it say from 1978 on? I am assuming these are model years. I believe we're talking about a 1971
The Fox
Carrera
Old 05-21-2004, 11:28 AM
Irrationally exuberant
ChrisBennet's Avatar
I've always replaced the flywheel bolts but if you read your factory manual you won't find "replace with new" until the dual mass flywheels. The dual mass flywheels used much longer flywheel bolts I think.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-21-2004, 11:35 AM
maxnine11's Avatar
kqw, you are correct, i didn't read the model year in Poorsche Man's signature. Sorry.
i'll edit my original post .
max
max
kqw kqw is offline
No problemo....Max.....
The Fox
Carrera
Old 05-21-2004, 11:38 AM
