Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
An update: slow progress and a question.
Well it's been a lousy couple of weeks for me but here's what's been going on. I still had some oil pressure problems. It would start with great pressure ~100psi then drop down very rapidly after only a minute. My crossover oil line had a small dent, nothing major but enough to be suspisious. I've replaced that and got about the same thing. Well after some head scratching we tested to see if we got any flow past the ext. thermostat into the tank. Nothing. Turns out in our R&R of the thermostat and ext. oil lines turns out the PO had installed the thermostat backwards!!! The larger of the two caps was pointed towards the car! definitly not right. I also pulled the internal thermostat which had previously tested ok. Well it turns out it's not working anymore. Of the three thermostats I have 1 works but it's from a 2.0T and it's orifices are smaller than the 2.4 and 2.7 thermostats that I was using. Will this be ok?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 05-15-2004, 03:31 PM
l wouldn`t use it.
my life begins at 150MPH
Old 05-15-2004, 03:34 PM
Bandwidth AbUser
Jim Richards's Avatar
That was some crappy news, Tim. I hope you get it sorted soon so we can hear about that great new(ly rebuilt) engine of yours.
Jim R.
Old 05-15-2004, 06:59 PM
Tim Walsh's Avatar
Jim,
It's slowly getting sorted out. Next up is that thermostat and leaning out the mixture a little bit. It's running VERY rich right now
Tim
1973 911T
2005 VW GTI
Old 05-15-2004, 07:33 PM
