Bilstein question
I am sure this subject is tired for many of you, I just cant find a good tech article on it. I am rebuilding a 74 911 and am looking to upgrade the front suspension first. I already purchased elephant bushings, turbo tie rods, upgraded the t-bars a little and sent out the arms for coating. I want to upgrade the struts, rotors, calipers, etc. Does someone have a rebuild list and some suggestions. Thanks for any help.
What is the desired end result? It might be wise to just get an entire 1984-88 front end and swap that in.
Regardless, I would replace or upgrade every piece of rubber there -- including the top strut mount. There are a ton of posts on the topics you want. |
Thread Tools | |
Rate This Thread | |
