oooh yeah, that's a hot looking setup
dave 1973,5 |
You mean "EVIL GENIUS" don't you Tyson.....
Famous last words.. "Hold my beer and watch this...' " The reason the Irish are always fightin one another is that there are no other worthy opponents ". |
Schleprock
Ingo,
Any opinions to offer on those Kumho MX tires?
Kevin L '86 Carrera "Larry" |
Ingo,
How are things working out with your 951 16x8 Fuchs on the rear of your narrow body car? I'm thinking about trying the same setup on my '71 911T. Have you had any rubbing? Thannks for the updates, -Kaefer |
I love it and have nothing but fun. Rubbing. Yes, ever so slighty on the passenger side (oil line and fender) under severe cornering (high-speed track) driving. It has not really bothered me. I could raise the car by a half inch and/or massage the fender a little bit more. But oh well.
However, be aware that you have to dial in more than 2 degrees negative camber to make this setup work. Cheers, Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
That extra inch makes a big difference in many facets of life !
Bob |
Guest
Posts: n/a
Tyson does good work. LIL evil genius
Do you plan on staying with 225/50/16 tires or would you recommend going with a 225/45/16? Thanks for the help, -Kaefer My 16x8 951 wheels should arrive late next week! |
I purchased a full set of 951 wheels, 2-7s and 2-8s. Are the 7's of any real use on an early 911, i.e., would it make sense to run the 951 7's in the front and 951 8's in the rear with lot's of negative camber. I would probably run 205/50R16's in the front and 225/45R16's in the back. This would be on a stock narrow body, does anybody currently run this combo? If so please post your thoughts and any pics if possible. Thanks!
Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver |
Andy |
Warren Hall Student
Michael,
951 and 911 7"x16"s are the same basic wheel only the 8"x16" has the different offset. So the set you have is the same basic setup as Ingo.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Thanks guys. Does anyone out there have more pics of 951 fuchs, especially the 8 inch wheels in the rear of an early 911?
Guest
Posts: n/a
Here are my custom 16x8's on the back of Shuie's car. He said they were perfect fit.
3 restos WIP = psycho
I'd like to see any of these cars lowered so the tires tuck inside the wheel wells without rubbing. Has anybody succeeded with 8s in this regard?
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
are the rear flares on a stock '74 more flared than a stock '70? I have installed 16x7's with 225/55 on the rear of my '70 and they rub when cornering. I have yet to add neg. camber.
Ingo, do you have any pics of the front? Any rubbing up there? -Dan 1970 911T
--Dan 1968 911 Coupe 1970 911T Targa 1995 993 Coupe 1997 993 Targa (sold) |
I just bought a 70 T on Friday. After reading this thread my day is made. My only question is that I am told that the 951 wheels came in two offsets. What is the offset number that I should buy?
2007 GT3 Red, 2008 Cayman S Track Car, 1970 911T Tangerine, 2019 AMG E53 4, 2020 S450 2019 F350 King Ranch R Gruppe Member #626 |
Schleprock
The 951 Fuchs came in only one offset- both the 16x7 and 16x8 are ET +23.3mm and were only offered to fit the 1986 944 Turbo. Then in 1987 along came a revision in suspension geometry and it necessitated higher offset wheels. I think this is where you got the information that there are different offsets for 951 wheels. The "phone dial" ATS wheels that were used on the 944 Turbo from 1986-1988 have two offsets. The 1986 phone dial wheels are 16x7/8 like the Fuchs and have the same +23.3mm offset as the Fuchs. The 1987 phone dials look almost identical to the 1986 wheels, but have a higher offset of +52.3mm
MBruns for President
You want 951-362-117-00 part number
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Schleprock
16x7 = 951.362.115.00
16x8 = 951.362.117.00 Note that the "00" is typically missing from the part number stamped on the wheel. You'll know the 951 wheels when you see them. The 16x7 looks like a 911 16x6 Fuchs, except for the countersunk lug holes on the 951. Same goes for the 16x8- it looks like a regular 911/930 16x7 except again for the countersunk lug holes
