Lorenfb's Avatar
I said the knock sensors could be disabled. I've seen a lot of 964s & 993s
where pinging occurred. I'd have to assume the knock sensors were disabled
since the pinging stopped when the stock chip was re-installed. As you know,
the 964/993 DME retards the timing in 3 degree increments to a max of 9
on EACH cylinder individually. It also slowly advances back to the original
timing setting.
Obviously, without dis-assembly of the hex code of the EPROM, one could
never really know. Something has had to happen to the knock sensor data,
since pinging occurred in the 964/993 cars I've been involved with.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 05-19-2004, 07:04 PM
Irrationally exuberant
ChrisBennet's Avatar
timing setting.
I was hoping you had a list of bad apples but that info is still helpful.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-19-2004, 07:25 PM
If I may add,....
I cannot say for certainty that the chip tuners I know disables knock-sensing on purpose. Without hard data, that would simply be conjecture.
I will say that some chip tuners are too aggressive with their timing maps and these cars will detonate under hot condtions and high loads. Further, some chip tuners do not test and development their products with the locally available octanes of the customer's.
One thing about the 3.6's,....if the internal distributor drive belt is broken, it can ping like hell no matter what gas is in it. Its caused by the lower rotor coming to rest pointing at a set of contacts and igniting that cylinder at the wrong time.
There are many reasons that these engines can detonate and the PST-2 or Hammer will display any unusual knock sensor activity.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-19-2004, 10:13 PM
Original Owner
tsuter's Avatar
Originally posted by Steve W
Ignition maps use RPM and the artifical load signal of the AFM to lookup the base ignition value. There is no reason that these base values cannot be trimmed by other factors such as the engine temperature, intake air temp, rate of rpm change, and in this thread, knock sensors. Think about it.
Perhaps some of you should stick to what you do instead of making statements about which you do not know.
Hahahaha... what a clown!!!
Show me the AFM software you use and I'll show you MAP.
Heck I'll show you mine anyway ..... but you can't have it.
Nanananaa!!!!
Or are just you one of these "theoretical guys"??
I already showed you how I can disable knock sensors. Now I'm showing you basic ignition maps as well.
LOL!!!
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 05-20-2004, 07:28 AM
Original Owner
tsuter's Avatar
Since this thread is supposed to be about knock sensors and how they may or may not work, here is a nice picture showing how they work.
Using vehicle ECM data logging.
I have the cursor (verticle black line) at data point 1774 and I am recording knock retard on the front and rear banks of between 4.5 and 8 degrees. See data section and graphics.
The total advaance thus has been pulled back to 26 and 20 degrees vs the master ignition map at that specific point.
The TP (throttle position sensor) is 100, the MAP is 98 and the RPM is at 5012 for this specific data read.
The EPROM calibration for this vehicle is factory.
AND it needs tuning. Badly!!!
tsuter
Thaaaats Right!!
Old 05-20-2004, 07:39 AM
Original Owner
tsuter's Avatar
Now the tuner (me on this one) goes to work on the EPROM tables and works to eliminate that power robbing knock retard via adding fuel at the appropriate points and or retarding portions in the ignition map.
Here is a data log of the exact same vehicle after several iterations of tuning focusing on fuel. The ignition map did not require edit and the knock retard was fully eliminated in this case.
Note RPM is 5045, TP% is 100 and MAP is 98. Essentially the same data run. the cursor is at data point 380
Let me tell you that vehicle owner could FEEL the difference when his ignition was no longer getting pulled 8 degrees!
Now no "reputable" software tuner is going to disable the knock sensor retard capability of good software without the owners consent. "Reputable" that is!!!
But what do I know,,, right????
edit: spark advance is now the 29 degrees specified in the ignition advance table cell MAP=100, RPM = 5000 with no pull back.
tsuter
Thaaaats Right!!
Old 05-20-2004, 07:48 AM
Nanananaa!!!!
LOL!!!
tsuter,
Did you reverse engineer the ECM to get the info your software is displaying (like Steve did) or are you just a "theoretical guy" when it comes to ECM algorithms?
-Chris
Old 05-20-2004, 07:56 AM
Original Owner
tsuter's Avatar
Chris, mine is displaying the actual ECM EPROM tables in the software windows and I edit them first off line after polling data then directly update (reflash) the EPROM tables with the new tables via the OBD port.
It ain't theoretical.!
edit: the factory ECM tables in the EPROM are completely overwrittten and unretrievable so best is to socket a new chip and keep the factory chip.
tsuter
Thaaaats Right!!
Old 05-20-2004, 08:09 AM
Embs's Avatar
Ain't this an ugly mess, thanks to tsuter and loren, some honest facts are being discussed. You bas-turds should be banned from the BBS, no more truth telling or I am going to report you. I demand only lies from this point forward.
Back on topic, I was worried that on especially the 993 engine during a hot day, chips that disregard the adaptive function of knock sensing may be causing major damage to the engine over time. It appears this is true. So you 3.6'ers better tune in.
Old 05-20-2004, 08:32 AM
Original Owner
tsuter's Avatar
Re: Performance Chips & Knock Sensors
Originally posted by Embs
NO CHIP WARS please......
Can a aftermarket and/or performance chip disregard the input from knock sensors and still allow the motor to run?
Todd
Yeah Todd you are right. I guess the simple direct answer to your question was... yes they can and yes the motor will still run.
But who likes simple???
tsuter
Thaaaats Right!!
Old 05-20-2004, 08:45 AM
I don't question your table values. I was just teasing you for infering that Steve's only a "theoretical guy" when he actually got his hands dirty and did some reverse engineering to acquire his knowledge of ECU internals and algorithms.
A "clown" would be someone who bought tuning software that doesn't even work on a 911 trying to school Steve on ECU algorithms. Of course that wouldn't apply to you. Of course.
-Chris
Old 05-20-2004, 08:56 AM
Original Owner
tsuter's Avatar
Chris, I'm not the one who said this:
"Perhaps some of you should stick to what you do instead of making statements about which you do not know."
And I'm still waiting for a real ignition table with other than RPM and MAP axis. One with about four variables and especially temperature. Hahaha!!
I think I'll be waiting a long long time!!!
edit: but maybe he meant Loren.... who knows..... who cares.
tsuter
Thaaaats Right!!
Old 05-20-2004, 09:11 AM
Steve W's Avatar
Nanananaa!!!!
LOL!!!
Young Padawan: you have much to learn. These are not GM motors. Porsche Motronics use either an air flow meter or a mass air flow sensor to determine engine load, not MAP sensors. The software we use is proprietary and custom written by us, there's no reason to try and display all it's functions, as it's not for sale. Here are screenshots from one of the programs we use displaying the base maps of a stock 89 Carrera. As you can see, with the x-axis representing the rpm points, the y-axis being the load from the AFM or MAF sensor, the Y-axis represents the fuel or ignition value. Using these base values, they can be trimmed and adjusted via the warm up tables, head temp sensor, intake air temp, rate of rpm change, knock sensors etc. Trimming these base values allows adjustment for such factors as high ambient temps to maintain a predesignated knock margin - especially for the 3.2 motors which do not come with knock sensors.
Old 05-20-2004, 09:40 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I will hook up a scope to the knock-detect signal of the diagnostics plug on my 3.6 soon. This is not the input to the DME but an output that "talks" to the Hammer. I don't think one needs a Hammer to display the signal. I'll keep you posted.
A chip for a 3.6 is essentially executable code for a 8051 microcontroller plus a data section. All that is stored in a non-volatile memory chip called EPROM (Erasable Programable Read Only Memmory) The computer (DME) has inputs (crank sensor, head temp, CSP, AFM, region plugs, oxygen sensor, etc) as well as outputs (FI, Ignition, etc). The program that runs processes these inputs and does numerous calculation with stored values in the data section of the ROM to generate outputs. Some of these data sections are aranged as tables. This is what people talk about when they talk about maps. Fuel maps and ignition maps for part throttle work like a lookup table. Based on two inputs (RPM, load) you get a numerical result. Many forget that this result is only one factor that goes into the equation of producing the final electrical output to the engine.
For the 3.6 there are different chips out there with different levels of modifications/approaches:
1. Stock code with modified maps for part throttle and full throttle. If these mods are not too agressive you can consider this a "safe" chip. Ususally one map is modified and all pointers to the different map point to this one (disabling the region plugs). Be aware of the gas quality the chip asks for.
2. Stock code with modified maps and modified base values for RPM limit, fuel cutoff, and other goodies. Caution, here you start to get into uncharted teritory. The rev limit had a reason and if you raise it the added stress will result in $$$$ if you haven't prepped the engine properly (rod bolts, valve train)
3. Completely different executable code. This is no mans land. You surrender your engine to whoever thought out this code. I would stay away from it for two reasons. This chip could have been made by a dumpass or it was made for a monster engine with all the goodies that comes appart after every race weekend. Go figure what that can do to your stock 3.6.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-20-2004, 10:09 AM
Lorenfb's Avatar
Great points Ingo, few really understand what they're putting into their cars
and how it may be affected. I've seen #3 on a 993TT where the car wouldn't
pass emissions because the OBDII diagnostics & readiness states were gone.
This was a '97 where the memory had been flashed and no original code
was available. The customer had to buy a new DME ($1200 - $1500).
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 05-20-2004, 10:55 AM
Original Owner
tsuter's Avatar
And YOU are gonna teach me about the merits of MAF over MAP??? That's OT for this thread sonny boy.
But I'm still waiting for more than two variables you claimed in that ignition table. Come on now show us the ignition trimming you are claiming for head temp, IAT, RPM delta...... shadow tables.... please???? In addition to knock sensors I guess????
No cold start idle advance or warm up enrichment tables now... we are talking about multi variable ignition trimming.
It is nice theory anyway!!! LOL
Oh and nice 3D by the way too!!!
tsuter
Thaaaats Right!!
Old 05-20-2004, 11:45 AM
Lorenfb's Avatar
I'm surprised I haven't heard this one (like the air temp):
Our chips optimize the timing based on the octane being used. We are able to
determine the octane level by use of a proprietary algorithm. We basically
calculate the piston's acceleration, which is proportional to the octane level,
by taking the derivative of the speed sensor signal. Knowing that value, we
are able to select the appropriate timing map for the octane being used.
As a result, our chips exhibit no pinging for a wide range of octane levels.
Sounds good to me. Whatever it takes to sell a product.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 05-20-2004, 09:15 PM
Original Owner
tsuter's Avatar
I run GIAC chip software (Garrett) on my race VW1.8T with their IBE Chipswitch software. Utilizes a key fob to switch from pump(91-93) to race(104), valet, to kill programs... up to five programs. Unfortunately they don't yet offer direct port programming like the Delphi Automotive software pictured above but they will eventually as DPP is what the market wants.
GIAC's IBE chipswitch is not currently available for all Porsche applications - only VW and Audi.
APR V-Tune is direct port programming but also only currently for VW/Audi.
As far as running Delphi on a 911 there is a thread on CIS to EFI converisons and if I ever converted mine (which I won't), I would only convert to some form of DPP software.
edit: For Steve W. Yes my VW uses a Bosch MAF sensor not a MAP and yes I know the difference!!! LOL.
tsuter
Thaaaats Right!!
Old 05-21-2004, 07:02 AM
If I may, I would like to add some $0.02 on knock sensing here:
Knock sensors are basically microphones. Some are (mechanically in manufacturing) tuned to specific sound frequencies that are created when an engine knocks. Others are broad band and the knock sensor interface in the ECU detects only those frequencies experimentally determined as knock signal for a specific engine.
The knock frequency is determined by:
f = M*c/pi*B
f is the typical frequency for the knock signal.
M is a 'Mode constant' for the different resonance modes in the cylinder. Depending when in the stroke knock occurs the Mode constant might change.
c is the speed of sound in the cylinder.
B is the AVERAGE bore size (taking into account the shape of the combustion chamber).
The speed of sound is calculated by
c = square root of (k*R*T)
where k and R are constants (1.4 and 247 respectively).
T is the average gas temperature in the cylinder at knock time in degree Kelvins.
So if the engine (or fuel) is modified by changine the combustion chamber shape, fuel type, deck height, fueling and so on, the temperature or knock position changes and knock (even if there) might not be detectable by the ECU, simply because the characteristic knock frequency for the engine changed. A lot of ricer kids blow up their engines with Nitrous because of knock. Their ECU never retarded because it was tuned in to the wrong knock frequency (gas temp difference).
Knock sensors are a very limited method of detecting knock and work well enough only for an unmodified or mildly modified engine. But all bets are off for a seriously build engine.
Old 05-21-2004, 09:25 AM
