Author of "101 Projects"
After hearing about people complain about not being able to resize and fit images so that they could be uploaded, I decided to incorporate a resizing routine into the website. Please help me test it.
The image upload feature should now allow you to post any JPG or GIF image of any size. It will reduce the size of the image on the server, and also constrain it to be 800 pixels wide or less (no biggie pics that crowd the screen). Try it out please - post your biggie images here. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Ill start it off
Tried it a couple of times, kept coming back "could not find server"
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Explain... -Wayne
Very nice feature Wayne!
That image was originaly 1600 x 1200 and about 864k. Now its exactly 800 x 600 and about 76k. Worked like a charm! |
Did not work Ok here goes, Image original size is around 1.3MB and size is around 1536x2048 Cheers Jakes Did not work, this is the error I got You attempted to upload a file totaling 1383957 bytes. This exceeds the maximum limit of 100000 bytes (100k). Please go back and select a smaller image. [edit] I did mine using the attach multiple option, if that is of any help.
If you want to run with the big dogs, you can't pee like a puppy!!! 92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!! 81sc / 3.2 litre transplant (Broken BIG Time ) SCWDP deserter - HP junkie wannabe Last edited by Siena911; 05-21-2004 at 02:38 AM.. |
Attempt to post image
Here goes Wayne:
Sorry, it didn't work. Here is the message: You attempted to upload a file totaling 439460 bytes. This exceeds the maximum limit of 100000 bytes (100k). Please go back and select a smaller image. Alan
1988 924 S 500 in US Black (the only color) 82 SC Guards Red/Black . (Sold) SSI's, No Cat, Bursch, H4's plus relays/wiring upgrade |
this one was 1024x768 size was 460k
87 Carrera Backdate |
Semper drive!
This is what I got back. Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
same pic saved as a huge 24-bit bitmap 2.25 mb. Using Xp pro and Explorer 6 128bits.
oops We're sorry, but you may only upload image files (with an extension of .gif or .jpg). Please go back and select a different file forget this one Wayne sorry
OK, I'll throw in a Rennsport pic that started off around 225k:
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
I posted a 550K photo in a new thread called test photo (by accident) and then another in the same thread - worked a treat - love it.
David Cayenne Turbo - Cargraphic Stage 2 Power kit, lowering module 997 C4 Cabriolet - Basalt Black 86 Turbo Body 911 Cab - Many Mods Gone and Missed: 97 993TT: PSS9, CarGraphic Exhaust |
First try (btw, what an improvement in convenience that will be!!!)
Ooops...nuthin showin...got "too large size msg"...
Belgik 1988 Carrera 3.2L Last edited by Paul Franssen; 05-21-2004 at 04:36 AM.. |
![]() 579K
worked cool
Second try...same (large size picture)
No dice... You attempted to upload a file totaling 1301288 bytes. This exceeds the maximum limit of 100000 bytes (100k). Please go back and select a smaller image
Belgik 1988 Carrera 3.2L |
I am using the attach multiple - try that Paul
Trying another picture...
Nope: You attempted to upload a file totaling 1117059 bytes. This exceeds the maximum limit of 100000 bytes (100k). Please go back and select a smaller image. Oviously, my pictures .jpg are too big anyway....
here is my try
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
I still get a message that it has to be smaller than 100,000.
