hifeverz's Avatar
Question Pointless Conversion Kits
RE: '74 911
I wanted to install a pointless conversion kit in my car. Petronix Ignitor or Crane Optical Kit??? I have both and will install either, depending on feedback of your experiences. I hear bad things with Petronix . . . and have heard nothing on Crane. Can anyone enlighten me to choose???
Thanks,
HZ
Old 05-19-2004, 03:18 PM
I have Crane, it's good.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-19-2004, 03:20 PM
Chuck Moreland's Avatar
And I thought this would be about 964 body kits.
Pertronix works well, provided it's installed properly. Trouble is, some versions have instructions that don't properly explain CDI installation.
Chuck Moreland - elephantracing.com - vonnen.com
Old 05-19-2004, 03:24 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Chuck it's actually about 959 body kits you just don't know it yet.
The crane kit doesn't look to be a bad one at all after seeing a good friend install it on his. I want do to put in the crane when my motor is running nicely.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 05-19-2004, 03:27 PM
I would rather be driving
jpnovak's Avatar
Are you sure its not about one of those Rolls Royce/VW beetle kits?
I have a Crane. Easy install. Works great.
Old 05-19-2004, 03:59 PM
No experience with Pertronix.
Crane. Install and forget about it.
Sherwood
Old 05-19-2004, 04:03 PM
Bye, Bye.
Scooter's Avatar
Hey, I am looking for this kit:
Elvis has left the building.
Old 05-19-2004, 04:54 PM
Installed pertronix in a 73T. Instructions that came with it were worthless. I posted a question here. Within 30 minutes Chuck had given me two sentences of instruction (it's only two wires after all!). It's worked flawlessly after that.
"Rust never sleeps"
Old 05-19-2004, 04:59 PM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Pertronix,
2 wires. One goes to 12V+ and the other goes to the wire that used to run to the points. Thats it. Just installed one in my 67S race car. Car has NEVER run better.
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 05-19-2004, 10:23 PM
Bird. It's the word...
Fishcop's Avatar
Very happy with my Crane XR700
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-20-2004, 06:51 PM
A Quiet Boom's Avatar
Had Crane XR700 on my old 2.0E worked great.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 05-20-2004, 07:51 PM
araine901's Avatar
Both are good, I had an awesome experiance with Pertronix. They did not make a mounting set up for the inside of my distributor. But for $20 and a week later they custom made one for me. Works great but I just use it as a trigger for my MSD
'66 911 (sold to Magnus Walker)
'63 Myers Manx
'67 Cal Bug
'02 GTI 1.8T
Old 05-20-2004, 08:24 PM
Fleming's Avatar
Pertronix for 911S
Bill Hoke at Pertronix has made a fitment for the 911S distributor (0231 159 002) the product order number is #1866.
This fits the original 002 and also the newer 050 style.
Bob Fleming
Old 05-21-2004, 08:25 AM
Bob you old dog How ya been?
I've also been thinking of an upgrade for mine. Will the Pertronix trigger a Permatune? I've been running the Permatune/mechanical points for 20 years and it's time to change.
Paul Bork
Old 05-21-2004, 08:33 AM
Fleming's Avatar
Hi Paul, the Pertronix will trigger the MSD AL spark box so I would guess it should trigger the permatune. But, anyone have this fitment working on their car?
When are you going to have that 6 running.
Bob Fleming
Old 05-21-2004, 03:08 PM
I've driven Crane XR700s for hundreds of thousands of miles, very reliable, never had a problem. Literally "set it and forget it" for the life of the car.
I've known a couple of people that have not had good luck with reliability of the Pertronix. Something about the glue in it, or something like that.
One even sent a bad unit back, only to get ANOTHER bad one as a replacement.
Old 05-21-2004, 04:33 PM
B D B D is offline
B D's Avatar
I use the Crane and it works great. Only issue that a few have had is clearance, a disc now sits below your rotor and raises it up. This may cause some rub on the cap, you can file down the part that rubs on the rotor or take some off the botom of the rotor for an easy fix. Also, if you have this problem take a look at the cap and the springs that hold it on and make sure they are even; the cap may have a slight tilt causing the rub or even making it worse.
68 911L
Old 05-21-2004, 04:39 PM
19 years and 17k posts...
azasadny's Avatar
I put a Pertronix kit in my '74 with CIS in 7/2002 and it's given me no trouble since.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 05-22-2004, 09:44 PM
Who sella the crane? Easy to install?
Old 05-23-2004, 04:40 PM
al lkosmal's Avatar
I've had the Pertronix for quite a few years now, First with the original Permatune, later with Bosch, and now with MSD. Works great with all of them.
RGruppe #669
http://www.x-faktory.com/
Old 05-23-2004, 04:51 PM
