Titanium Brakes
Has anyone seen the titanium brakes that Bavarian Autosport has in for the M3?
I was flipping through a catalog at a firends house this weekend and came across them. They seem really cool, the only thing is that by looking at them they look really thin. Could they really dissapate heat so fast that they can use that much less material? Seems like the way to go for weight savings if they work well. "The rotors are made from titanium for superior strength, better heat dispersion and amazing weight savings. (Example: for a 97 M3, a 13” rotor weighs about 5 lb. vs. 17 lb. for stock) The billet aluminum calipers (7 lb. vs. 12 lb. for stock) feature internal porting for safer fluid transfer. "
Automotive Monomaniac
The rotors don't have much surface area.
![]() How much?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
I would rather be driving
I looked... $8K for front/rear kit.
Ouch!! That's a big brake kit and a lot of Pagids for that much. Great idea though! I wonder if those slots are chamfered to reduce milling of the pads away? I'd like to see some feedback from a track session comparing identical cars with std brembo type kit and this Ti system.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Irrationally exuberant
Back in 1996 Peter Albrecht addresses this issue on the long gone Porschefans mailing list. I thought it was very enlightening so I saved it.
-Chris Quote:
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
You've got to wonder if they are really "that good" or more "bling" factor.
Porsche has gone ceramic, when they could have easily gone titanium. I wonder what the arguments are for/against. Do you think the titanium rotor has the friction like iron/ceramic?
That post is rather enlightening, and brings up some of the points I was thinking about.
One of the guys I used to work with worked at Boeing as an engineer for years and told me that titanium has some weird properties. Unlike other metals that distort or pick up new properties when heated or cooled, or banged on with a hammer, Ti has those, but also does weird things at speed. He said that some of the planes are 10 inches longer in flight due to the speed and even a couple of the stealth bombers leak while on the ground, but have a perfect seal in flight. Strange stuff, none of which sounded like it would help braking any. The weight is cool, but the heat capacity may not be there. Definately Blingin' though.
Registered Loser
Seems like Ti is a poor choice for brake rotors. But I hear it's perfect for gas pedals.
Owner of a wrecked 944 |
-Chris
Hmm, I wonder how many people are going to be really screwed by those Ti rotors??
Chris B, that's cool, I must have missed a post somewhere.
Very high bling bling factor. Very low performance factor. Ti galls very easily and has poor heat sink capabilites. Currently used in caliper pistons to insulate fluid from heat. Why then put it in rotors? They are supposed to absorb heat.
Funny stuff. The aluminum case is probably pretty nice though.
'83 SC |
I bet titanium calipers would work. Keep the rotors ceramic or iron.
Administrator
What the heck is the briefcase for? Are they so valuable that you cuff them to your wrist and bring them separately to the track?
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Hmmm, interesting - I'd like to hear what Bill V. has to say about this.
The quoted post above is mostly correct. There are some (newer) alloys of Ti with better resistance to stress crack failure. Also, you can polish it, tho that doesn't seem like a good solution for the face of a rotor.... The main thing holding back the use of Ti is the high cost to refine it and to work the material (the latter is just like the case with SS years ago). Ti is extremely abundant however, more so than most metals, and the costs are coming down. You can get some sense of the way the Ti industry is going by reading the annual reports of Ti "smelting" companies -- and many of these are posted on the web. Thermal conductivity and heat capacity are not always a benefit in rotor design -- witness PAGs ceramic brakes, which surely have very low values of both those effects. These are not much more costly than the Ti option above, and will likely be cheaper in the future - the use of them seems to be expanding despite the initial problems. |
driver
- chris Street: 1971 911E, 2007 GTI 2.0T, 2012 Cayenne Turbo, 2019 GTI TCR, 2022 Boxster 25 years Circuit: 2020 Cayman GT4 |
Registered Loser
Author of "101 Projects"
If titanium were so great, then Porsche would be using it (or have used it) in their competition braking systems a long time ago... No one's talked about the Aluminum calipers? -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
The Ti rotors are available in the usual 13, 14 and 15" sizes for our cars they run ~$1400/ea. they generally incorporate a ceramic coating which needs to be reapplied after each weekends use. The Nextel guys are experimenting w/ them, but the verdict isn't in. Mostly on Super speedway rotors which are surprisingly small anyway(non vented).
They are used by a lot of the Sprint and midget guys w/ good success in lighter less stressed applications. Replaced regularly of course. For our cars cast iron is an almost ideal meaterial despite its mass. The PCCBs are all being pulled in favor of good old cast iron for track use.
I remember the aluminum rotors that were out a few years ago. I guess they had a metal spray coating for wear resistance. I saw some at a shop and the mechanic said they didn't work and were being pulled off the car. Anyone have experience with these?
As a side note, it looks like F1 maybe pulling the carbon/carbon brakes to reduce costs. I've felt for years that this one change would improve races dramitically by making passing possible.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
The aluminim metal matrix rotors were just that , an aluminum composite structure. They were not up to the task.
