LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
Mike Bonkalski's Avatar
Unable to get proper rear toe-in alignment
My alignment guy and I are stumped on our inability to dial in any rear toe-in on the right rear. When the eccentric is at the end of its range, we are still at a toe out situation. The eccentrics have been 180'ed to see if it would help - no luck. All of the other wheels are spot on.
Any suggestions on why we can't get the toe set correctly?
Btw, the reason for the alignment is installation of new polybronze bushings and monoballs.
--Mike
1971 Targa RS - Sold
1964 BMW 1800Ti
1969 BMW 2002
Old 05-25-2004, 12:33 PM
You need to set camber first.
IIRC you need about negative 1.0 degree (sometimes more) to get toe, especially if it's lowered.
Good luck.
Nick
'85 Carrera
Old 05-25-2004, 12:35 PM
We had the camber at negative 1.8 degrees with no luck.
1964 BMW 1800Ti
1969 BMW 2002
Old 05-25-2004, 12:36 PM
Is it close?
My alignemnet guy(s) said to try and hollow it out, but I was afraid of that.
I am out of ideas then, unless it the ride-height is REALLY low, or too high?
Nick
'85 Carrera
Old 05-25-2004, 12:42 PM
Now what I understand is that they are running out of room where the spring plate meets the swing arm. He said it seems like the swing arm is too long.
1964 BMW 1800Ti
1969 BMW 2002
Old 05-25-2004, 01:10 PM
Somewhere in the Midwest
MotoSook's Avatar
Mike, did you notice this before the rear mono ball install? You've got aluminum trailing arms right?
Old 05-25-2004, 01:23 PM
I will have to go through the PO documentation to see if I can find any old alignment info. I didn't take any toe measurements prior to dismantling to install the monoballs and bushings. I didn't notice any odd handling characteristics while driving the car, but it was mostly highway and around town driving.
Yes, the trailing arms are Al.
--Mike
1964 BMW 1800Ti
1969 BMW 2002
Old 05-25-2004, 01:28 PM
I don't think the ride height is too low, or too high. I measured it at 25.25" prior to the alignment.
--Mike
1964 BMW 1800Ti
1969 BMW 2002
Old 05-25-2004, 01:29 PM
MotoSook's Avatar
You've got an SC suspension on a 71 chassis right?
Perhaps someone out there who has done the conversion can tell you what is up. I can't think of anyhting off the top of my head right now....wish it were a Friday afternoon, I'd run over too Jms and get greasy just to find out why...I'm intrigued!
Old 05-25-2004, 01:36 PM
Its a Carrera rear suspension on a '71. Jim and Joe are both working on it now. I'm about the head out of work now and go on over.
--Mike
1964 BMW 1800Ti
1969 BMW 2002
Old 05-25-2004, 01:40 PM
MotoSook's Avatar
I wonder if your problem exisited before and you just didn't notice.
Old 05-25-2004, 01:48 PM
Irrationally exuberant
ChrisBennet's Avatar
On an 80's 911 when you crank in a lot of negative rear camber (more than 1.5deg for example) it causes the suspension to toe out. At some point the there isn't enough adjustment in the spring plate to get toe back (in) where you want it. The fix is to lengthen some holes in the spring plate. I can't remember which ones.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-25-2004, 03:31 PM
spring plate
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-25-2004, 08:14 PM
Chuck Moreland's Avatar
The problem exists on the passenger side only? Could be a bent trailing arm.
Is the toe eccentric freely rotating 360 degrees? or is it limited in travel due to the rear bolt holes Ron is referencing above? You can test this by removing one of the bolts, or replacing it temporarily with a smaller diameter bolt. If so, use a file to elongate the slotted holes.
Are you make the adjustment with the weight off the wheels? You'll find more range if you unweight it.
Chuck Moreland - elephantracing.com - vonnen.com
Old 05-25-2004, 10:57 PM
If none of that works, some clever work with a welder and a file and you can move the toe hole forward a bit on the spring plate.
Or some clever work with a welder and lathe and you can accentuate the eccentric adjuster a small bit.
There is always a solution.
Old 05-25-2004, 11:02 PM
jluetjen's Avatar
My car has the same problem and I put to down the the previous owner parking it againsts a guard rail at Watkins Glen. I attributed it to bent chassis, although I haven't been able to confirm it with measurements. I opened up the hole that you described, but I also had to do the same thing to the slotted adjuster hole to give it enough travel.
Since the problem existed with the original steel bananas and the aluminum bananas that I have since installed, I still believe that it is the chassis or torque tube.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 05-26-2004, 03:46 AM
Not Quite Banned
Thomas Owen's Avatar
You may find here that the problem already existed. Perhaps you can make some basic measurements across the underside of the car and see if the torsion tube is swept back on the right side from impact.
Good luck-
Thomas Owen
1972 911T
1972 911S
Old 05-26-2004, 03:58 AM
What would have the highest margin of safety, using a smaller bolt or enlarging the hole?
It concerns me a bit to start shaving off metal from connection points or using non-spec bolts.
--Mike
1964 BMW 1800Ti
1969 BMW 2002
Old 05-26-2004, 05:03 AM
Good luck-
An old 70T I previously owned had exactly that problem. Half an hour on the frame rack cured it and dialed right in afterwards.
Tim
Old 05-26-2004, 06:28 AM
Just talked to the alignment guy. It looks as if the aluminum trailing arm is bent, the rest of the frame is spot on.
Off to the classifieds to find a trailing arm. Thanks for everyone's help with this issue.
--Mike
1964 BMW 1800Ti
1969 BMW 2002
Old 05-26-2004, 06:52 AM
