Why is it that the simple things are always the hardest?
How on earth do you slide the left side heater hose onto the engine panel? The old one fell apart when I went to take it off to replace my wires so I bought one from Pelican. It feels thicker than the original so it's not as flexible. I can't bend it enough to get it to slide down to where the old one sat. It's on there now but it's not the way it should be. Is there a trick to doing this? Am I not bending it enough? I'm afraid that if I bend it too much it will crease or something. I also thought of cutting a small slit in it to help it slide down better. What am I doing wrong?!?!?!?
JUAN
'80SC Targa
Old 06-03-2004, 07:22 PM
keep trying amigo,you`re almost there
my life begins at 150MPH
Old 06-03-2004, 07:51 PM
Damn raceman! I came back online and saw a response to my thread and thought OK, some one has the answer! Nope.
Thanks for the support though.
JUAN
'80SC Targa
Old 06-03-2004, 08:21 PM
always there for a brother!Add some soap to allow easy fitment,hard soap rather then liquid works well as does window cleaner....
Old 06-03-2004, 08:32 PM
See, you guys always come up with something. Thanks, I'll try it tomorrow.
It won't blow bubbles out of the exhaust will it? Don't want to look like Lawrence Welk driving down the street.
JUAN
'80SC Targa
Old 06-03-2004, 08:58 PM
Designer King
Paulporsche's Avatar
"Ah wan anna two anna..."
-L. Welk
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-04-2004, 02:07 PM
