Look for a Thread...PLEASE HELP
There was a guy with an early 911 or maybe a 912 that did a completely custom rear suspension set-up utilizing hime joints and lots a fabrication. I believe that the car was orange and had 993 cup rims. I just finished searching about 100 pages of threads and cannot find the post...someone please help.
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks -- www.britainracing.com -- |
Britain,
Testing my memory and search capabilities here but was it presented in Chris Streit's Coil-over thread? No room for coil-overs. Now what? Getting close?
Warren & Ron, may you rest in Peace. |
Nope...not in that thread either. This set-up had completely revised rear suspension that did not use the banana control arms. He had built a box around the tranny and fabrication a set-up similar to the ERP front suspension using hime joints and tubing.
PLEASE HELP ME FIND IT! -Britain
"Hyme" joint is sort of an old fashioned term for the generic rod ends. If you change your search to use the other spelling I show and/or "rod AND ends" you might find it.
I would rather be driving
Look for MY912RS or something similar for a login name
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Somewhere in the Midwest
Look in the "Winter Projects" thread. The owner seems a bit secretive about his project or doesn't have time to post. He's a manufacturing engineer I believe.
It's Heim -- and it's not Jewish....
Also see a recent Rennlist thread re putting an entire 993 rear into an earlyt car (!) |
I still can't find it...ANYONE?
-Britain
Sure -- your Google finding reminds me of an EBay trick - search under an alternative spelling to find items with fewer bidders driving up the prices.
Jamie, I was thinking of the second link you posted. I couldn't find it though. Good work.
Oh the user name is MT912RS. I just did a search on the partial name. Popped right up.
