grahamkissack's Avatar
wise to check head stud torque during valve adjustment?
I am just finishing my first valve adjustment. Is it wise to check the head stud torque? I've learned in past if it isn't broke don't screw with it...and my engine is running fine. Comments?
Thanks, Graham
"Penelope" 1980 SC Targa in Grand Prix White
Old 06-10-2004, 10:34 PM
Now in 993 land ...
aigel's Avatar
If you do a search, this subject has been discussed, if not beaten to death.
My conclusion was to play it safe and check the nuts, but not torque them, leave alone re-torque them.
I put the allen head socket and ratchet on them and very lightly applied some torque. Mabye 5ft/lb tops. That way I knew no studs were broken - all I wanted to know.
Hope this helps.
George
81 SC (sold)
Old 06-10-2004, 10:44 PM
I apply a torque wrench only, and Only clockwise.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-10-2004, 11:18 PM
Senior Member
Superman's Avatar
I'm a big proponent of retorquing, or at least torquing clockwise only. Upon rebuilding my engine I found only one broken stud, but three heads were damaged due to beating against the cylinder tops. Particularly after a rebuild, put a torque wrench on them and make sure they are still correct. There will be adjustments.
Mocha 1978 911SC. "Coco"
Old 06-11-2004, 05:26 AM
"Cheap is expensive"
Why not? I did even though not much happened since I have raceware and they were re torqued after 2kmiles and then I did it at 10k when the engine was out.
Old 06-11-2004, 05:30 AM
Irrationally exuberant
ChrisBennet's Avatar
If you are using the torque (only) method on non-corroded nuts, retorquing in the car makes some sense. Otherwise, a simple low torque "test" to see if they've come loose is all I'd feel comfortable with.
"The earlier torque-controlled method of the tightening the cylinder-head bolts has been replaced by the method of torquing by degrees of turn. The method of torquing by degrees of turn applies to repairs on all 911 Carrera engines (84 models onward)." From the Factory Carrera manual p 15-8d
Two Stage tightening:
Stage 1: 15Nm (11 ftlb) in specified sequence
Stage 2: 1 x 90 def +/- 2 deg in same sequence
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-11-2004, 07:11 AM
I kind of asked this same question in another thread.
1. How many shops do you think check this when adjusting valves?
2. Will pulling the engine off the car merit a differnt level of examination?
Old 06-11-2004, 07:16 AM
bump
Old 06-11-2004, 08:39 AM
ckissick's Avatar
I mainly wanted to reply because we almost have the same last name, and a very rare one at that.
Anyway, why check the torque? Suspicious oil leaks? If there are no leaks in that area or other symptoms of something going wrong, perhaps it's not necessary.
Charlie Kissick
Montara, CA
1970 911E
1950 VW
Old 06-11-2004, 09:47 AM
