Virginia Rocks!
Size of allen wrench for CIS Fuel Adjustment??
I think I'm trying to adjust the wrong screw when attmepting to adjust my CIS fuel mix.
I have seen a number of posts where the allen wrench should be a 3mm. Using Wayne's book, and following the photo, I found a hole next to the boot and the F/D that's 5.5 mm. Am I trying to adjust the wrong screw? It's a really tight fit for my tools/hands so I'm thinking I have the wrong one. Is they one actually behind this hole? (Any got a photo handy?) Also, how much can the idle screw turn before noticing it on the tach? This wouldn't be the first time I goofed something up. ![]() Many thanks all!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
3 mm allen wrench, very long one. It takes 1/8 of a turn to get 1.5-2% change in CO mix.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Virginia Rocks!
Re: Size of allen wrench for CIS Fuel Adjustment??
The hole I was trying to adjust was right next to the boot, I must have wrong one. Can you see this hole without a mirror while looking at the engine?
This is the factory tool, 3mm
You do not have permissi
Should be 3mm, same as VW CIS. I wonder if the distributor units/lines/injectors/WUR are compatible as well.
Meanwhile other things are still happening. |
Virginia Rocks!
Ok. I'm going to give it a crack again tommorow, once it's done raining.
Does anyone know how much I can turn the idle adjustment screw before I will see a change? I turned about 1/8 and didn't see any change. Admittedly, my mix is kind messed up (rich)Thanks
Designer King
You should only turn the screw a max of 1/16 turn each time.
The hole is on top of the mixture control unit, to the right of the boot. To lean, turn counterclockwise, as viewed from the top. Leaning typically raises the idle, and richening decreases it. Do you have an airbox popoff valve? Is it seated, sealed, and located correctly? On my car, a too rich mixture causes a fluctuating idle speed, while too lean causes the popoff valve to pop open. The correct mixture produces an almost black, very dark brown color to the inside of the tailpipe, and the engine revs freely to the redline. If you have a gas analyzer, you should be somewhere 3.5% CO according to JW, although each car will vary somewhat. I also find I have to redajust my mixture slightly richer by 1/16-1/8 turn each fall, and lean by the same amount in mid spring, although my temp range here in Toronto would be more drastic than yours in VA. If this is your first time, make sure you are engaging the grub screw down inside under the hole. Good luck. Paul
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Hey Steve..
Somethings to keep in mind. When I first tried to adjust my mixture the hex wrench would just turn freely. Weird?! Well it turned out that the previous owner dumped a bunch of locktite down there and covered the hex adjustment screw. I wound up using picks to get it all cleaned out, but it was a very unusual circumstance. A good thing to keep in mind..... right - rich (clockwise) left - lean (counter clockwise) Just one small click at a time. Its sensitive. If you have trouble turning it....with the engine off, take off the air filter cover, and reach in and hold the sensor plate with one hand firmly, while you adjust with the other. Bob 73.5T/CIS |
Designer King
Take the allen key out after each adjustment and rev the engine. Then drive the car, or test w/ analyzer.
Once i had debris fall into the hole and clog the screw. A thin wire should clean it out, or I had good luck dropping a little WD40 down the adjustring key shaft into the screw head, then cleaning it out before adjusting. Paul
Virginia Rocks!
OK, I will give this a try tommorow. Assuming I get the mix sorted out, how much does the idle screw (on other other side by the heater fan) turn before noticing adjustment?
Thanks!
Designer King
Just a wild approximation: 1/8 turn should give you something like 100 RPM. As far as I know, you cannot cause any engine problems from over rotating as with the mixture unit, since it just allows more or less air to bypass the idle adjuster, so if it is not enough or is too much, just give it more.
Paul
Steve, do not adjust anything in the motor-bay without dropping the motor first, that's the law in NoVA
![]() Try to find someone who has analyzer for best results. My freind Jon Estrella in Leesburg has one.
George My Owners Gallery Page 1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running. 1995 BMW 525I 2001 Highlander- kid mover Last edited by GB83SC; 06-11-2004 at 04:00 PM.. |
hey, i dont know much about this because i just bought my lambda car. an 81 SC. i know there is a trick of the trade of using a dwell meter set on the 4 cylinder setting where you can read your mixture. you hook the dwell meter to the lambda signal duty cycle test connector. start car and warm it up. and turn the 3mm allen until the dwell meter reads 45deg. you will nail your CO mixture. but there is a disclaimer that all other ignition and injection parts must be in good working order. i guess instead of sticking a sniffer into the exhaust pipe, you use the lambda sensor as the sniffer. genious. i will locate the duty cycle test connector tomorrow at a PCA tech session on tuneups.
cliff p.s. a 5.5 mm allen fits perfectly through the hole but will not seat within the 3mm allen head. that is why you are turning and not getting any change. you bigger tool is just riding along the top of the allen. you will feel clicking or "indexing" when you get the right tool during the turning.
poof! gone Last edited by vash; 06-11-2004 at 04:46 PM.. |
Designer King
Neither my 77 nor my 80 engine mixture adjustments would produce "clicks". You would have to guess the amount of rotation by feel. Does anyone know which years click?
Paul
Virginia Rocks!
That must be my problem. I'm off to give it a whirl! George, I'm just hoping to get it going enough to make it to Porsches Under the Stars tonight. We can drop the engine tommorow. (Or I'll talk to Jon about the gas analyser!)
my old stock CIS ran better at 3.5 with the dizzy vac permanently disconnected.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Virginia Rocks!
Thanks, all. I see what I was doing wrong. I didn't realize the wrench had to drop into the hole a ways. Could they have made this more difficult to reach?
