Case Stud torque values
case stud torque specs
Does anyone have torque specifications for installing case studs (not head studs) for the inner studs on both halves of the case?
My machinist pulled some of the studs to do the machine work, forgot to reinstall them, so I have to reinstall them.
Also, do I need to loctite them?
Also if anyone has a list of all the torque values for the case studs that would be most helpful. I don't have that in any of the documentation that I have.
Car is a 3.3L Turbo - 1983.
Thanks,
Brian
briankeithsmith@ctc.net
Brian Keith Smith
Old 06-11-2004, 08:22 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
To insert the studs into the case, not close the case, i believe there is no torque required just thread it in till it hits the bottom. You might want to pick up waynes rebuild book btw.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 06-11-2004, 09:09 PM
Thanks, I've got the book, and parts of the factory workshop manual, but haven't seen any tables that indicate the specs on those inner studs or heights. Maybe I'm overlooking it.
Thanks,
Brian
Brian Keith Smith
Old 06-12-2004, 05:13 AM
