sscates's Avatar
Question Oil Filter change question
Okay, help me out. I heard the secret to not getting oil all over the place. Punch a small hole in the filter and use compressed air to empty the filter into the tank. This sounds easy, but wouldn't this possibly put some bad stuff back in your oil tank. I hesitate to change my filter half way through the oils life because it makes such a mess. Any thoughts on this? Is this what the mechanics do when your car goes in for a change?
Old 06-13-2004, 05:01 PM
HOw about just stuff two rags under the oil filter, quickly spin in off, wife off the excess, spray it with some carb cleaner, wipe, and forget about it.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-13-2004, 05:12 PM
Location: member Central PA Region PCA , Home of the Hershey Swap
I would be concerned about blowing the filtered sludge back into the motor. Not a good "technique", IMHO. Just place a bunch of paper towels under the filter and dispose.
regards,
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Irrationally exuberant
ChrisBennet's Avatar
Making a mess removing the oil filter is not a problem with these cars. The technique you refer to was recommended in a recent Pano for use on Boxsters I believe.
You're more likely to make a mess putting oil in a 930 than removing the filter. A small funnel with a big mouth/"tube' gets around that problem.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-13-2004, 06:04 PM
Zeke's Avatar
Boxster filters spin on from underneath. They are in a housing that is reused. You don't poke a hole in that. You'd have to blow the oil straight up anyway. Must have been another car.
You could poke a hole in the top of the 911 filter if you just pulled in off the road. I wait 15 minutes after draining the tank, not much oil in there to worry about.
Old 06-13-2004, 07:14 PM
Jeff Alton's Avatar
Zeke is right. Just wait a few minutes and there is no mess.
Jeff.
www.turn3autosport.com
Old 06-13-2004, 10:18 PM
