custom 2.7RS air filters
Hi all
may you tell me where i could find custom air filters for my 2.7 Rs engine ?
(recent thread : "my new twin plug system pictures"
Philippe
Old 06-14-2004, 12:41 AM
Mike Bonkalski's Avatar
Philippe,
You can find those filters here in the States at the following link:
http://www.coastfab.com/home.html
I think they are an English product. Their home page is as follows:
http://www.itgairfilters.com/
1971 Targa RS - Sold
1964 BMW 1800Ti
1969 BMW 2002
Old 06-14-2004, 07:01 AM
thanks
Philippe
Old 06-15-2004, 01:41 AM
anybody know if of some trick weathershield type air cleaner housings for PMOs. I wanted the Wolfert but they only do an occasional batch.. How about trick valve covers.. again NG at CMW. I've been searching for over 18mo.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-15-2004, 11:01 AM
Ron,
What the dif between the filter mounts for Webers and PMOs? Aren't they the same?
Sherwood
Old 06-15-2004, 11:58 AM
Originally posted by 911pcars
Ron,
the same watershields.. which I have now. I tried getting the Wolferts.. my name is on a list for over a year. I'll buy used Wolferts if I could find them.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-15-2004, 12:31 PM
Randy Webb's Avatar
A year? Buy a Bridgeport and make some....
Also a guy named Carbon Joe (search old threads) makes light watershields out of CF -- the new PMO watershields are heavy much more so than the old ones on Webers.
Old 06-15-2004, 05:44 PM
I saw the CF.. they're very nice.
Pelicanhead Hugo w/an early black 70s 2.7 & Webers had them over here in Long Beach. Now his 3yr completed project is for sale.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-15-2004, 06:24 PM
A Quiet Boom's Avatar
LOL, you'll need a little more than a Bridgeport to make those, like a rotary table for example. FWIW Ronin I'm planning on making some billet tops for my watershields once I get my rotary table. If they turnout well I'll post here. Nothing too fancy, just going to ball mill some groves in the top and chamfer the edges.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 06-15-2004, 07:14 PM
the owner of the machine shop that mfg Wolferts told me his rigs cost a fortune.. and that the housings were started as entertainment for a good friend. and that he'd probably do another run if he got 50 customers for them.
so do you need another good friend?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-15-2004, 08:33 PM
that's interesting. I'll ask around for some eyeball entertainment.. thanks
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-15-2004, 08:44 PM
Randy Webb's Avatar
1. I think the ones on my old (1980's or 90's) Webers were Al. The ones PMO is shipping are magenetic, so steel. Very nicely made, etc. but as I recall you can save about 2 lbs. .....
2. You don't really need all the fancy stuff on the bottom of the Wolvert covers. A Bridgeport will make great looking covers ..... or you can braze the round items on the bootom if you think they are important.
Personally, I plan to go with CF but first have to get my oddball tranny mounted up right.
Old 06-15-2004, 09:21 PM
1 You don't really need all the fancy stuff on the bottom of the Wolvert covers.
I donn'tt about that
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-15-2004, 09:24 PM
LOL. No I don't need another good friend to make these. I have a manual mill which means each cover would be hand made. What I need to get started on this and a few other projects for the P-car is good 12" rotary table to cut the curved edges. I already have sheets of 1/4" aluminum as well as the end mills and ball mills etc. I had the idea even before I got the mill. I saw a look I like on a street rod once, very simplistic and functional but good looking at the same time. I've been scanning ebay for the right table, just haven't found one I want yet.
The guy that wants to do 50 probably has a CNC mill and wants to justify setting it up. My brother has been considering getting a manual/CNC mill and doing piece work to help pay for it, that would be the ticket for several items I have in mind for P-cars.
Old 06-15-2004, 10:28 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
is everyone so hot to put carbon fiber parts on their car's because it looks cool?? unless the pieces are autoclaved they are not worth the price at all, you get none of the strength. fiberglass would be better suited for it and is cheaper to use. plus you can put dye in the resin to make it look almost like cf. i plan on making some filter mounts in alu. and fiberglass once the engine is rebuilt. that will be a few months.
74 911s neverending story. two feet and a jetta for now.
Old 06-15-2004, 10:37 PM
Randy Webb's Avatar
Ron - look at the bottom of the PMO covers -- flat.
Old 06-15-2004, 10:39 PM
oh.. I was thinking of the bottom base that funnels the rain water.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-16-2004, 04:34 AM
Randy Webb's Avatar
OK. But if I was driving in rain (which I do 6 months/yr) I would go with the watershield types.
Old 06-16-2004, 05:35 PM
the Wolfert's lower base is designed to discharge water before it goes into the carbs.. whatever
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-16-2004, 08:59 PM
I assume that's only when the engine isn't running? Seems to me the vacuum would suck the water right in if it was running. Makes sense though, it would take a lot of water to shut down a running engine, but the carbs could fill up if it where just parked in the rain and the regular watershield base was used without horns.
Old 06-16-2004, 09:30 PM
